09-08-2009, 09:53 AM | #1 |
Newbie Join Date: May 2008 Location: Biloxi
| Ball Bearing steering for CC01 with Hilift parts
Here is an easy way to improve the steering on a CC01 chassis without haveing to machine parts. A few drill bits, 3 HiLift kit parts, and a little plastic modification and your done http://www.scale4x4rc.org/forums/showthread.php?t=39199 |
09-08-2009, 11:50 AM | #2 |
Quarry Creeper Join Date: Oct 2006 Location: Amsterdamned
Great I did one too and after miles of trailing she still steers without any problems. Another CC-01/XC steeringmod, cheap but solid ... |
09-08-2009, 11:59 AM | #3 | |
09-08-2009, 12:00 PM | #4 |
Quarry Creeper Join Date: Jan 2008 Location: san jose
looks good. I made my own a few months ago but it just broke in 1/2 after I let my buddy drive it. |
09-08-2009, 12:24 PM | #5 | |
Quarry Creeper Join Date: Feb 2008 Location: Clymer, NY
09-08-2009, 02:12 PM | #6 |
I would post it up here but it wont let me post pics |
09-08-2009, 02:37 PM | #7 | |
0 0 Join Date: Jul 2006 Location: FT. Thomas
just the pics | |
09-08-2009, 03:07 PM | #8 |
Just the words Ball Bearing CC01 Steering with HiLift Parts There are a few good tutorials on how to improve the CC01 steering. Most of these, however, involve the user creating his own steering shaft. This tutorial will show you how to add ball bearing supported steering to your CC01 using HiLift parts and a little plastic cutting and drilling, no machining necessary. Heres the parts: 3/8 and 25/64 drill bits (to drill out chassis) (x2) 5x10 ball bearings (x1) BF 14 "steering shaft" from HiLift kit (x2) G15 from HiLift kit (x3) 2x5mm screws (x1) 2x10mm screw B6 + B11 from the CC01 kit STEP 1 Drill out Chassis using a 3/8 drill bit followed by a 25/64 drill bit. If you start with a 3/8 you can drill it out by twisting it by hand, no need to worry about wrecking your chassis with a power drill. Follow the 3/8 bit by the 25/64 bit, again twisting by hand. A little light sanding and you have a tight fit for the 5x10 bearings. If you want, you could drill it out bigger to use 5x11 bearings, but I didnt want to take this much material out of the chassis. Top bearing I fittted flush with the top. Lower bearing is inserted app. 5mm from the bottom. NOTE - you can use a spacer between the bearings if you like, but I didnt feel it was absolutely necessary seeing as how tight the bearings are fitted. STEP 2 Building the lower steering arm. Take one of the G15 HiLift parts, cut off the round part (part with the internal splines) as close as you can to the flat part. File a "flat" on two sides of the round part you just cut off, across from one another, insert into CC01 lower steering arm. Glue the two parts together. Insert HiLift part BF14 "steering shaft" into the two bearings, push on your new lower arm, secure it to the shaft with a 2x5mm screw. NOTE - By filing the "flat" on each side of the splined insert to fit tightly inside the CC01 lower arm it should not slip. Mine fits super tight and there is no way it could spin. STEP 3 Building the Upper Steering Arm Take the other G15 part and cut as shown. Cut the CC01 part as shown. Drill out the CC01 part with a 11/32 bit. Fit the parts together. Glue. I also drilled a hole through the side of the new arm and "pegged" the two parts together with a 2x5mm screw on each side. Slip new upper arm on steering shaft, secure with a 2x10mm screw, and you are done. And you are done. Now you have a CC01 with ball bearing steering using off the shelf parts, no machining required. Steering is very tight, with no slop, and since it rides on ball bearings, it shouldnt stick. |
09-08-2009, 05:11 PM | #9 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
Romulus, Im not seeing the pics... just dreaded x's. anyone else having the same issue?
09-08-2009, 05:23 PM | #10 |
09-08-2009, 05:26 PM | #11 |
or try this. not sure if it will work http://www.scale4x4rc.org/forums/att...1&d=1252414225 http://www.scale4x4rc.org/forums/att...1&d=1252414659 http://www.scale4x4rc.org/forums/att...1&d=1252414659 http://www.scale4x4rc.org/forums/att...1&d=1252414976 http://www.scale4x4rc.org/forums/att...1&d=1252414976 http://www.scale4x4rc.org/forums/att...1&d=1252414976 http://www.scale4x4rc.org/forums/att...1&d=1252415316 http://www.scale4x4rc.org/forums/att...1&d=1252415316 http://www.scale4x4rc.org/forums/att...1&d=1252415316 |
09-08-2009, 06:59 PM | #12 |
Nope, have to be a member there to view them. Photobucket is FREE and simple to use.
09-08-2009, 07:17 PM | #13 |
well i tried to help. i'm not going to put them in my photobucket though.
09-20-2009, 10:18 AM | #14 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
very cool mod. thanks for sharing. just sign up over at scale... there is tons of other info over there that doesn't get passed on to here. besides, it's free and painless. it's a lot less " pirate " over there... just go check it out. Last edited by crunky; 09-20-2009 at 10:31 AM. |
09-20-2009, 02:12 PM | #15 |
| Scale4x4 |
09-20-2009, 02:12 PM | #16 |
| Scale4x4 and their nazi mods |
