03-13-2010, 08:41 PM | #1 |
Newbie Join Date: Oct 2009 Location: eugene
| cc-01 pinion?
can i use a 12 or 14 tooth pinion as long as it is 48 pitch meteric? want to slow the thing down and give it more torque. |
03-13-2010, 09:12 PM | #2 |
Rock Crawler Join Date: Dec 2007 Location: St. Cloud
If you are using the stock motor plate you can only use the two pinion sizes listed in the kit (16t and 20t). The motor mounting holes in the plate only will allow those two sizes for the proper gear mesh.
03-13-2010, 09:48 PM | #3 |
| thanks
mabye someone needs to make a motor plate with adjustable mounting holes for the cc-01. thanks for the reply. |
03-14-2010, 08:51 AM | #4 |
Newbie Join Date: Sep 2009 Location: EU
Buy motor 55T to 70T - speed and torque will be OK
03-14-2010, 09:47 PM | #5 |
Rock Crawler Join Date: May 2007 Location: Glendora
You can also install a gear reduction unit (HPI, RC4WD, ETC..) to slow it down and give it some major torque.
03-18-2010, 12:30 AM | #6 |
Rock Crawler Join Date: Nov 2005 Location: dallas
I made an offset motor plate and run an 11t berg pinnion on mine, I like it
03-18-2010, 12:32 PM | #7 |
Quarry Creeper Join Date: Jan 2004 Location: Bend, OR
03-18-2010, 08:12 PM | #8 |
03-19-2010, 12:52 PM | #9 | |
| Quote: | |
03-19-2010, 09:46 PM | #10 |
The aluminum ring is is the motor mount, the stock plastic motor plate bolts to it I think you could also use adjustable motor mounts for a clodbuster I just didnt have anything laying around so i just made smething up http://www.tcscrawlers.com/Thunder-T...0-p-16167.html |
