06-03-2011, 07:54 PM | #1 |
Newbie Join Date: May 2011 Location: Mishawaka
| what you like/dislike about the cc-01
Im so close to getting one but im wanting to know what every likes/dislikes about the cc-01. Ive read that the stock tires arent all that great, is this true? |
06-03-2011, 09:46 PM | #2 |
Rock Stacker Join Date: Feb 2011 Location: Hong Kong
like: scale look dislike: bath tub chassis limited suspension travel, limited mod potential(mod without cutting anything) |
06-03-2011, 10:21 PM | #3 |
Newbie Join Date: May 2009 Location: Japan
Likes: The chassis (super realistic underside), and the overall look of the vehicle. I also like the attitude of most CC01 owners, that "it can be made to work" attitude that inspires modification and experimentation. Dislikes: The stock shocks, the bendy rear links and the lack of an included front diff lock. Jingles. |
06-03-2011, 11:52 PM | #4 |
I wanna be Dave Join Date: Aug 2007 Location: santa monica
I dislike the lack of gearing choices, stock tires are rocks, the transmission cover that is sensitive to improper tightness. Dont mind the plastic links. Never noticed them bending if they do. Love everything else about them. Mostly love how stockishly scale they look and drive. You have to watch where you place a tire to get over obstacle (more challenging to drive). Love the low CG! Love the width-better look on many bodies. mmm, width |
06-04-2011, 01:51 AM | #5 |
Newbie Join Date: Jul 2010 Location: Salem
likes: stock scale appearance the "it will work, you just have to make it work." idea like in the old days before anyone could go and buy part off the shelf and be just as good as anyone else dislikes: getting one second hand with a chopped up worn out chassis. |
06-04-2011, 05:48 AM | #6 |
Newbie Join Date: Jan 2011 Location: North East Ohio
| Likes: 1) Best value for my hard earned $$$ 2) Love the scale look. 3) Comes with decent light unit to get started with. 4) High potential for customizing suspension, drive-train, bodies, lighting, etc. 5) The only "must have" at time of build is a full bearing set. Otherwise you can have many hours of trail beating before having to worry about upgrades, or improvements. 6) Tires, suspension arms, steering components, are all fine/adequate for getting started. then you can have time to drive the buggy, and decide what you personally would like to upgrade, and save the money for it. 7) Quite a few "direct fit" upgrades available. This chassis seems to lend itself to lots of modding, so that tons of other parts from other manufacturers will fit. Your imagination is your only limiting factor. Dislikes: 1) Steering system could be improved to be tighter, and last longer. 2) Gearing is limited for motor/tranny options. Could use a motor mount with slots to allow for greater choice of gearing and adjustability. |
06-04-2011, 11:00 AM | #7 |
Quarry Creeper Join Date: Aug 2009 Location: Portland
Like: Realism (lots of stock scale points) Uniqueness Tamiya build quality Mods take some creativity Dislike: Does not sidehill too well Stock steering sucks. Mods take some creativity (yes this is both like and dislike) I have 2 of them and love em though (both original release XC's) |
06-04-2011, 03:29 PM | #8 |
Likes all the things mentioned above dislikes, only have 2 ,wish i could have them all |
06-04-2011, 06:38 PM | #9 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
Dislikes: Stock gearing Stock steering Stock rear suspension Stock tires Ground clearance Lack of decent aftermarket parts Likes: Lack of decent aftermarket parts Highly capable with minimal mods Extremely capable with major modification Tamiya durability Low CG Small rear axle ring/pinion (better clearance) Narrow track width Check my build thread to see what can be done with a CC01 to make it ultra capable. High Clearance CC-01 Power to the portal! Last edited by chino63; 06-04-2011 at 06:43 PM. |
06-04-2011, 07:09 PM | #10 |
Newbie Join Date: Jul 2010 Location: Georgia
Love almost everything about it but I wish there were more upgrades available.
06-04-2011, 07:10 PM | #11 |
I wanna be Dave Join Date: Apr 2009 Location: Unnecessary Surgery Land
I have a love/hate relationship with cc-01s. I used to think they were cool, but now I only use them for scale factor, not for performance. Likes: IFS Narrow track width Dislikes: Steering. Still sucks with Aluminum upgrade. Gearing |
06-08-2011, 03:59 AM | #12 |
Rock Crawler Join Date: Jul 2008 Location: Williamston
Likes: The Scale look The Price Dislikes: Tranny cover Steering |
06-09-2011, 03:58 PM | #13 |
Quarry Creeper Join Date: Feb 2007 Location: Lleida
Dislike: No rigid front axle |
06-12-2011, 11:10 PM | #14 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
what they all said..well all but the rigid axle comment, I don't mind the IFS....with some work and support from us, you can get a pretty good scale rig. Won't jump over trees, but it will get the job done...and if you can run with a axial scale rig, go any where it can...you are a good driver. Meaning, takes practice and makes you think on what your next move. get one, you won't be disapointed...unless you think it will crawl 90 degrees right out of the box. Last edited by squatch71; 06-12-2011 at 11:23 PM. |
06-13-2011, 12:18 AM | #15 |
Quarry Creeper Join Date: Oct 2009 Location: Twentynine Palms
The thing people need to understand is that a scale rig isn't a comp crawler. And an IFS rig probably won't be as good at really gnarly terrain as a solid axle rig. But if you're going to be driving your scale rig over scale terrain, then the CC01 does just fine. That and it's the only (unless you count the Kyosho that's impossible to find) IFS/solid rear chassis on the market and that alone makes it unique. It's not going to out-crawl an SCX10, but it'll follow most of an SCX10's lines. It's still a very capable trail rig and if you're going for the ultimate scale with most modern vehicles, IFS is the way to do it. The steering is sloppy, the bath-tub holds dirt, the gearing options are limited, but you guys have to remember this chassis design is 20+ years old. Tamiya really needs to give us a CC02. But for all it's quarks, the CC01 is still a great, durable chassis to build on. |
06-14-2011, 05:17 AM | #16 |
You said it. I love the freeking things. They are too cool! TODD |
06-14-2011, 10:14 AM | #17 |
im wanting one due to the scale look of these.
06-14-2011, 07:36 PM | #18 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
Hate: Bumpsteer from hell Slop Steering Love: Scale looks |
06-14-2011, 11:57 PM | #19 |
The green LR3 in this video is my cc01. Stock chassis except for addition of rc4wd gru. http://www.youtube.com/watch?v=IzsD7ag1su0 and here too http://www.youtube.com/watch?v=uVvERTv2VvQ It is pretty capable for what it is and its one of my favorite rigs. |
06-23-2011, 07:32 AM | #20 |
Newbie Join Date: Nov 2006 Location: Poquoson
Love the scale looks Dislike the lack of mods available and front suspension travel |
