12-22-2011, 04:40 PM | #1 |
Newbie Join Date: Oct 2011 Location: Mebane
| I need help making new spur/pinion gear options.
My cc-01 finally works. I'm giving it to my brother for Christmas. But, I'm also borrowing it to do a project for my physics class dealing with how changing gear ratios in a transmission changes torque and top speed. I'm using a trailer that I built to tow various weights and timing how long it takes to travel X distance. this car has been "heck". I had to hand build both sets of body mounts, installed 2 motors cause the first got too hot, 2nd works great, custom fitted a Newbright jeep body, made LED headlights, hand made a servo horn and clevis thing, re-programed ESC, bought flysky gt3b TRX & RX, changed battery from 7 cell to 6, rebuilt entire rear axle, greased EVERYTHING, fixed rear left shock. I think thats it. My problem is that in order to do the testing, I need at least 3 different gears, including stock. My question is what gears should i change, where to get them/how to make them work, and what tooth #'s to get. please help. |
12-22-2011, 04:41 PM | #2 |
| Re: I need help making new spur/pinion gear options.
By the way, This entire project is due on the 9th of january, so, there's a bit of urgency.
01-01-2012, 08:49 PM | #3 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
there is only 2 different pinion sizes you can use.. 16 and 20 i think
01-02-2012, 09:28 AM | #4 |
Quarry Creeper Join Date: Jan 2011 Location: Waterford MI
There's no different size spur gear for the cc-01. And there's only two different pinions 16 & 20.
01-02-2012, 09:30 AM | #5 |
But you cAn use a gear reduction unit to change ratios.
01-05-2012, 02:42 PM | #6 |
Rock Crawler Join Date: Dec 2011 Location: Las Vegas 89110
all the above,,,no spur but if your really handy you can make 1 and yes only 2 pinion options,,,,you can make a 3rd pinion option by figuring the mounting spot and adding the 2 new motor mounting holes
I need help making new spur/pinion gear options. - Similar Threads | ||||
Pinion / spur options for the AX10 trans | Mazlem | Kyosho Crawlers | 3 | 10-27-2011 08:46 PM |
spur gear pinion ? | wkxtreme | Newbie General | 4 | 06-28-2008 10:04 PM |
Help finding replacement spur gear for cc-01 OR MAKING ONE | aljsc2566 | 1.9 Scale Rigs | 3 | 01-09-2008 09:35 PM |
Axials Scorpion Pinion and Spur Options | BGGruff | Axial AX-10 Scorpion | 8 | 11-19-2007 12:35 AM |
What spur and pinion gear? | bigmike07 | HPI Wheely King | 1 | 09-30-2007 07:40 PM |
