08-07-2014, 10:24 AM | #1 |
| CC01 gearing and reduction chart
Quick reference chart for gearing. Only worked it out to axle RPM. Basically I was stuck - I liked the overall speed range with a 65t motor, but was lacking for torque. So I wanted to find combos of higher turn motors and reduction units that would keep overall wheelspeed the same and give me more torque. With so many options, I wasn't quite sure where to begin, and buying GRU's is not cheap. Using RC4WD's specs on their motors as a standard (assuming 7.2v) I worked out approximate ranges using various motor winds and reductions. A 35t motor and 4:1 are both here on the bench, so they are going in! Should keep my overall speed the same, but give me more torque. We'll see how it goes. Hopefully this helps anyone looking to gear down. As always, this is just a guide - actual RPM's can vary, especially among manufacturers. Last edited by OSRC; 05-27-2015 at 09:56 AM. |
08-07-2014, 11:55 AM | #2 |
Quarry Creeper Join Date: Oct 2004 Location: Beckley
| Re: CC01 gearing and reduction chart
Thanks for posting this. I have the hpi gru and am thinking about changing it out for a 4:1 to regain some wheel speed. This will be a huge help.
08-07-2014, 01:39 PM | #3 |
Ditto, use one in my other truck. It's great for scale running, but I cannot take that truck out on a trail run. Just cannot keep up.
08-09-2014, 06:51 PM | #4 |
Quarry Creeper Join Date: Feb 2008 Location: Oakdale, MN
Totally agree on the HPI GRU. It has the torque but a snail moves faster than my rig with the stock silver can motor.... Thanks for posting this up! |
08-10-2014, 06:00 AM | #5 |
Pebble Pounder Join Date: Apr 2013 Location: Germany
Thanks for the chart, very helpful. My CCs have either the HPI or Electrifly GRUs and have enough wheelspeed through a 3S Lipo |
05-27-2015, 08:19 AM | #6 |
Newbie Join Date: Sep 2009 Location: Newcastle, United Kingdom
I know this is an old post but could be both stickying this one awesome help this one, Thank you
05-07-2020, 04:30 AM | #7 |
Newbie Join Date: Jan 2019 Location: N Ireland
I have just created my own speed calculation. With Tamiya's stock 540 motor and 14.67 gearing ratio. The maximum speed worked out to be 10.4 MPH? I'm certain that mine was fast with 55T motor, I must be missing something. Stock tyre diameter is 90mm. |
05-15-2020, 12:36 PM | #8 |
Never mind, the calculation is right, having just played my CC-01 yesterday. With my 55T crawler motor @ 8,000 rpm, it is 5.7 mph which is about right. |
CC01 gearing and reduction chart - Similar Threads | ||||
Gearing chart | eric113 | Axial Wraith | 25 | 02-08-2017 02:09 PM |
gearing ratio chart | mark32 | Newbie General | 11 | 03-31-2013 09:52 AM |
Speed and Gearing chart? | acrosteve | Electronics | 3 | 08-07-2009 05:03 PM |
TXT Tranny - GD600 Gearing Chart | cheapjeep2 | Tamiya Txt-1 and Juggernaut | 1 | 06-09-2009 07:59 PM |
