Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: Schlabinski's CC-01 FJ Cruiser
Old 06-03-2009, 12:44 PM   #1
Default Schlabinski's CC-01 FJ Cruiser
I originally put this together about 2 years ago, but now that we have this nifty XC/CC-01 forum here I thought I would share.
My home brew ball bearing steering upgrade...
I used stock front end hackings to create a new front skid that improves approach angle and looks factory-ish:
Ultra smooth Tamiya aluminum 3 inch shocks with RPM spring retainers and Traxxas ball ends:
I replaced the stock ball ends in the steering links and upper suspension links with Traxxas ball ends to reduce play:
To obtain the perfect wheelbase for the FJ Cruiser body and reduce play in the suspension, I replaced the stock 4 link:
Traxxas Jato driveshaft:
My first attempt at wiring LEDs from scratch. The power is provided by the 6 cell stick pack that powers the truck:
A few pics of it all together:
Driving it in the basement in the dark is fun!
Thanks for looking,
Jeff
schlabinski is offline   Reply With Quote
Old 06-03-2009, 01:43 PM   #2
very clean. nicely done!
pantablo is offline   Reply With Quote
Old 06-03-2009, 09:08 PM   #3
Wow thats really clean. I'm working on my FJ right now and got some good ideas. What shocks are those?
rquarte is offline   Reply With Quote
Old 06-03-2009, 09:26 PM   #4
Thank you both! The shocks are Tamiya DF-02 front shocks, part number 53701. You have to buy two sets in order to get 4 of the 3 inchers.
Old 06-03-2009, 09:32 PM   #5
A few pictures from my first real outing on 9/23/2007...
Old 06-03-2009, 09:40 PM   #6
Even before my first real outing with this rig (pictures above), I wanted to install a gear reduction without having to modify the stock battery location. Credit to JasonInAugusta for posting the picture of his CC-01 chassis with a GD-600 and Revolver2 motor which provided the solution that I was looking for, and many thanks to Holmes Hobbies for patiently answering all of my questions and steering me in the right direction for the ESC and motor. I ended up with the Scorpion 2215 outrunner, a Quark 33a Procar ESC, and Castle Creations BEC. Here is how it all went together...
Removed some material from the transmission cover/motor plate holder to make room for the GD-600:
GD-600 attached to the motor plate (in the 20T position). Notice the material at the bottom of the GD-600 that will need to be removed otherwise it pushes up on the transmission cover and upsets the gear mesh with the spur:
The shaved GD-600:
Installed with only minor trimming to the electronics plate:
I decided to use the 20T metric 48p pinion on the GD-600 so that it would swing towards the steering servo instead of the other way:
Everything is wired up and ready to go:
Thanks for looking,
Jeff
Old 06-03-2009, 09:44 PM   #7
Some more pictures from an outing on 11/04/2007...
Old 06-03-2009, 10:00 PM   #8
Hateraide
Code454's Avatar
thats a nice and clean FJ good job
Code454 is offline   Reply With Quote
Old 06-03-2009, 10:06 PM   #9
After quite a bit of convincing from some local ORCRC friends, I decided to run the FJ Cruiser in the 1.9 scale class at MSD Scale Nats 2009. I picked up some new tires and wheels, some progressive springs for the rear, and waterproofed the electronics. Here it is ready to go...
Some pictures from course #2 (thanks to War Pig for taking them)...
This thing surprised me in Montana. I'm pretty sure I was the only one running a CC-01 in the 1.9 class. A disadvantage in a lot of situations, but in some it excelled. I quickly realized that I need a winch and tow points for the front and rear. I also wouldn't mind a little more wheel speed, so I will probably move to 3s LiPo. Most importantly, it was a blast...especially the course that these pictures are from.
Cheers,
Jeff
Old 06-03-2009, 10:17 PM   #10
I love that thing. Nice job
hellbentrodder is offline   Reply With Quote
Old 06-03-2009, 10:51 PM   #11
very nice work on the reduction unit and you maintained the battery location and the electronics plate. well done.
Old 06-04-2009, 12:26 AM   #12
Jeff... as always your rigs are almost too nice to even run. Very clean work. Still amazes me that you've had this rig for almost 2 years and Montana is probably the first comp with it. Great job.
We need to get you out to the scale comps local so you can hang out with the other CC-01 rigs.
toyofast is offline   Reply With Quote
Old 06-04-2009, 12:28 PM   #13
Thank you all for the nice comments!
Thanks Brett! Montana was indeed the first comp, and hopefully not the last with this rig. I hope to make it out to most of the scale comps with my 2.2 SCX for sure.
Old 06-09-2009, 04:09 PM   #14
If i remeber right your rig was one of my insperations to build a CC01 FJ sometime last year. Well i built the rig, ran the crap out off it, sold it and here i am again looking at your thread thinking damn i have a FJ body all i need is the kit, AGAIN!! Once again nice rig.
finishline is offline   Reply With Quote
Old 06-15-2009, 02:46 PM   #15
That makes two of us!
bmuzz1 is offline   Reply With Quote
Old 06-15-2009, 03:39 PM   #16
that's an awesome little rig man, great photos and nice tech also!
dieselfuel is offline   Reply With Quote
Old 06-15-2009, 03:57 PM   #17
Jeff I loved watching this rig wheel out in Montana. Glad we got to run course 4 together so I could see just how capable this rig is. Now I'm thinking about building a rig like this. Great build thread, tech, and pics.
PANDAbox is offline   Reply With Quote
Old 06-16-2009, 01:09 PM   #18
That's fun to know...thank you! I keep hearing over and over how previous CC-01 owners regret selling theirs. My new favorite advice: never sell a CC-01!
Hey Andrew! Course 4 was great...I really appreciate your winching help. Adding a winch is on my list of things to do to the truck since Montana. It was great to meet you and I'm glad you could make it from California. You should get a CC-01...you'll love it!
Old 06-19-2009, 02:20 PM   #19
don't worry James.. she's taking good care of it.. regardless of the paint..
NSR_CIVIC is offline   Reply With Quote
Old 07-15-2009, 09:14 PM   #20
Time for a little update. After competing with this in Montana in 2009, it really needed even more steering and a winch. I removed some material from the c-hub to get the knuckles to turn a little bit farther, and added MIP CVDs.
Scrounged up some old TA-02 MIP CVDs (thanks to the Utah guys for the part number guidance)...
Compared to stock...
Installed...
For the winch, I modified a Hitec 645MG for continuous rotation and mounted it on the chassis where the throttle servo would normally go...
Thanks for looking,
Jeff
