Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: CC01 Rear end trouble...
Old 02-15-2018, 05:52 PM   #1
Default CC01 Rear end trouble...
I was out with my son driving our trucks and he was driving the CC01 and it locked up and would not move forward or backwards. I open up the rear axle to find the inside of the diff full of black plastic shavings. It looks like the diff is chewing the inside case. Anyone else have this trouble?
gsgraber92 is offline   Reply With Quote
Old 02-15-2018, 06:27 PM   #2
Default Re: CC01 Rear end trouble...
Screws backed out of ring gear grinding into the case?
scalemadness is offline   Reply With Quote
Old 02-15-2018, 08:38 PM   #3
After cleaning out the grease and plastic shavings I found a diff screw had come loose. Little lock tight and a good cleaning and smooth as butter again. Thanks for quick replies.
CC01 Rear end trouble... - Similar Threads
Reworked front end in aluminum. Now with fastback style rear end. Plush Axial Wraith 7 01-03-2018 12:04 AM
Lifting the CC01 Front end mud-sweat-gears General Scale Talk 1 01-21-2011 08:40 PM
