Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: slow reverse...?
Old 06-20-2009, 09:10 PM   #1
Default slow reverse...?
I just got my crawler going today and after watching a few videos on here, my reverse seems slower than the rest. Is there a reason for this...how do i change it? thanks
boosst is offline   Reply With Quote
Old 06-20-2009, 09:42 PM   #2
DBR
For guys to give advice, it might help to throw in what you are running...
DBR is offline   Reply With Quote
Old 06-20-2009, 09:54 PM   #3
2s(will be 3s next week), Integy 35t w/ 16t pinion, Mamba max, CC BEC. I have regreased and removed shims in front and rear.
Old 06-20-2009, 10:14 PM   #4
DBR
Is the throttle on your radio set to 50/50? I haven't used a mamba before but everything else should have you going same speed front and rear. Or at least something that is not dramatically different.
Old 06-20-2009, 10:18 PM   #5
TEAM MODERATOR
Reflection's Avatar
If you've messed with the throttle and brake curves in the Mamba,that could effect having a slower reverse.
Reflection is offline   Reply With Quote
Old 06-20-2009, 10:20 PM   #6
it's sounds like a radio or esc problem,,there is no mechanical reason that I know of for this
grouser is offline   Reply With Quote
Old 06-20-2009, 10:52 PM   #7
i did change the throttle curve a bit in the ESC. I will go back in and put it back to default and see what that does. thanks!
Old 06-21-2009, 08:11 AM   #8
I had the same problem and it was my ATL set at 50%. A low EPA for reverse will do the same thing.
Steve. is offline   Reply With Quote
