02-20-2010, 12:39 AM | #21 |
Newbie Join Date: Aug 2009 Location: san jose
2 month old losi lipo battery bad already? and also a 6 cell nimh battery also 2 months old now I find it hard to believe that they only last 2 months:-( |
02-20-2010, 01:04 AM | #22 |
Rock Crawler Join Date: Mar 2009 Location: Frisco, Texas
02-20-2010, 05:07 AM | #23 |
Quarry Creeper Join Date: Dec 2009 Location: armpitts, CA
when i was running 2s for the longest time i used tekin 35t motor. as far as binding gos. just watch ur wheel tire placement soft front foams help too.
02-20-2010, 07:47 AM | #24 |
Quarry Creeper Join Date: Feb 2010 Location: Tucson
Did some more trouble shooting last night. I know now that it is definitely not that battery. In the 1st 3 minutes of running it on a fully charged battery it seemed to had lost power and would not climb anything. The motor was really hot right away. I put it on flat ground and drove it around for a few minutes and then back to the rocks. All the sudden it worked perfectly, crawled just fine and the motor quickly cooled back down. I ran it for another 1/2 hour with no issues after that. Makes me think that the motor is bad????? What do you guys think?
02-20-2010, 08:21 AM | #25 |
Pebble Pounder Join Date: Oct 2009 Location: Rapid City
I guess you could get a cheap 35t intergy lathe motor and try it out. As far as my problem it is not the battery I hooked a amp meter up to it and ran it when it would bind there was not a spike in amps (the truck was not demanding current). Pluse I have tried many differnt lipos from 2 - 3 cell same problem accross the board (one is a 35c hyperion 63 amp capacity).
02-20-2010, 08:35 AM | #26 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
Hung brush, bad bearings/bushing, loose motor mount causes excessive binding when gear mesh tightens up. Could be many things.
02-22-2010, 09:19 AM | #27 |
Well, I figured it out. I wound up getting a Trinity 45t motor and that solved the problems, the stock motor was bad in one way or another. Glad I did though, I didn't gain any wheelspeed really but the torque is waaay better! I might try going up to maybe a 23 tooth pinion but with the worms I don't think I will get much more wheelspeed without heating the motor up too much!
