05-14-2011, 07:29 PM | #1 |
Newbie Join Date: Apr 2011 Location: Rocklin
| battery/servo tray for lnc Hi i was wondering if anyone has seen or made a battery/servo tray for the lnc.i would greatly appreciate it if anyone could point me in the right direction, thanks. this is my first thread so plz excuse any newb mistakes i make. im also fairly new to crawling. |
05-14-2011, 07:33 PM | #2 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
are you talking about like an ax-10 offset servo plate, that moves the servo to one side and allows you to put the battery up on the front axle. or are you talking about a servo mount and battery tray that would be in the stock centered location, but would have the battery hanging off the backside of the axle. the first one, i know highlandcrawler is running one that he made on his. the second style, cdw makes a bolt on piece, and many (like myself) make their own.
05-14-2011, 09:27 PM | #3 |
Pebble Pounder Join Date: Apr 2011 Location: DOWN SOUTH!!*LONESTAR*
if you dont wanna make a tray over the axle you can still cut out a lexan sheet and mount it on the front upper links cut it out to shape and ziptie it. the i use velcro to secure the batt. The servo trays are a little more complex though.
05-15-2011, 12:34 AM | #4 |
Quarry Creeper Join Date: Feb 2008 Location: Albany
I sudjest reading every thread under losi CC / NC. All sorts of tricks & ideas. I bought the srevo / batt kit from rob b. Here is alink to his thread . Awsome set-up! I cant say enough good things about it. Also look into RcBro's stuff. Another great guy to deal with!!!!! |
05-15-2011, 10:32 PM | #5 |
thanks for the help im using a massive Nihm batt so it wont fit on the upper links and i wod like one like the ax10. Im only 15 and i dont have the money to go lipo or brushless though id love to. thanks again
05-15-2011, 10:43 PM | #6 |
even if you made a new servo plate, i don't think you'd be able to lay the battery next to it, unless its a smaller mini size battery. i made an aluminum one that did the same as i'm running now, but would fit the nimh battery. problem was that it ran into the chassis pretty bad. the best way i found to relocate the battery low was to re-arrange the electronics, and run the battery on the rear axle. had to throw quite a bit of weight in the front tires to get something that didn't make the rear end try to pass the front on descent.
05-16-2011, 02:22 PM | #7 |
i might try that. thanks for the help
