12-11-2011, 01:02 PM | #21 |
Pebble Pounder Join Date: May 2006 Location: Chico, California
Thanks for the tips. as for the shaft angles they are pretty extreme but I have not been able to test it as the rear shaft is now at the point where it only sits half way in. I need to find a way to angle the axle a bit or find longer shafts to keep the shaft in place. I do need to brace the shock mounts as they do tend to twist as does the whole chassis with my coat hanger braces in place. I have extra link material i can make the braces from. Any reason not to do bend links on the front end as well? Thanks again |
12-11-2011, 01:17 PM | #22 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
i don't see a reason not to, i ran bent front and rear on the stock chassis no problem at all. you'll notice now that your fronts will take a lot of beating, taking the brunt of the impact on doing break overs. and those lnc lowers will start flexing BAD the more you run it, i could bend mine to the point the eye to eye on the ends was only about 2 inches. keep the uppers though, they're about bomb proof....good plastic molded around a steel core, kept em as long as i could.
12-11-2011, 01:30 PM | #23 |
I am currently looking for info on limiting my shock travel which will also bring the axle angle back in line a bit and solve my shaft issues. Any body got a link to how to place a block inside the shock or another way to do this.
12-11-2011, 01:36 PM | #24 |
gotta take the shock apart a lot of the way to do this, or take the rod end off and use a lot of lube to make sure it doesn't eat the o-rings. as far as limiter, most use nitro fuel line, i use some stuff i found that is used on an old planter....works good. at least on the lnc shocks, there's a couple e-clips holding the piston on the shaft, pop those off, put tubing on, pop back on. not sure about your new shocks, may be different.
12-12-2011, 03:39 PM | #25 |
Rock Crawler Join Date: Sep 2011 Location: Richfield
If you still have a problem with the LNC shafts being too short, The LCC shafts will fix this. They are telescoping and longer than the LNC.
