12-28-2011, 03:34 PM | #1 |
Newbie Join Date: Dec 2011 Location: NL
| 13.5T brushless pinion
what size pinion for a 13.5T brushless motor ? thanks |
12-28-2011, 03:40 PM | #2 |
Gold Star Baby! Join Date: Jan 2011 Location: SOUTH JORDAN, UT
| Re: 13.5T brushless pinion
Try different sizes and see what works for you... I have tried 12,14, 16, 18. And after all of my trial and error I found that the 14T works best for me.
12-28-2011, 08:51 PM | #3 |
i think i'm running a 13t...i like it. I haven't tried any others though.
12-29-2011, 06:31 PM | #4 |
I wanna be Dave Join Date: May 2010 Location: The east coast
Does the 13.5t give some good wheelspeed? I have a goat 3s and I'm running lnc axles and a lcc tranny in my scx10 based scaler.
12-29-2011, 07:17 PM | #5 |
Pebble Pounder Join Date: Dec 2011 Location: Mount olive
I have a 20t on my lnc with goat 18.5 it's ok but I want lil more wheel speed so my lcc tranie will be here tm they say that it has daf gear ratio so we will see
12-30-2011, 01:06 AM | #6 |
watch the vid you can get a really good idea of the kinda wheel speed I get out of a 13.5 motor with a 14T pinion. December 24, 2011 3:34 PM - YouTube |
12-30-2011, 09:57 AM | #7 |
Quarry Creeper Join Date: Mar 2010 Location: Los Angeles
Looks a little cold in that video...
12-30-2011, 09:33 PM | #8 | |
Rock Crawler Join Date: Oct 2009 Location: Knoxville
12-31-2011, 04:42 PM | #9 |
Great vid Redrokin, just what i needed to decide on a pinion for when my CC arrives this week. What size lipo you using ? |
12-31-2011, 07:58 PM | #10 | |
| Re: 13.5T brushless pinion Quote:
The temps stay low. Never too hot to touch it. But I ran 4 packs through it on that day and it got a little warm. It's a Ballistic 13.5 I run a 2S on it. | |
01-01-2012, 09:12 AM | #11 |
Another ? Redrokin/guys Whats the Dimensions/capacity of the 2s ? Does it fit in the stock position ? Runtimes with a 14T pinion ? If i run a 1300 3s 25C pack, would i need to go to a 12T pinion with the 13.5T Brushless motor? Last edited by rhino20; 01-01-2012 at 09:49 AM. |
01-01-2012, 01:35 PM | #12 | |
The 3S..... You can still run the 14T, the only difference between the 2S and 3S is more wheel speed.... Just depends on how much ya want I guess. If it were me I'd run it on the 14 and make adjustments as needed. It's all about setting up the Crawler to your personal preferences and driving style. | |
01-01-2012, 05:58 PM | #13 |
I joined the Band! Join Date: Mar 2010 Location: nashville,TN
mine is stock motor/esc and im running a 31t, to big? i dont do any comps just more less drive it like a southern buggy.
01-01-2012, 06:16 PM | #14 |
| Re: 13.5T brushless pinion Seeme like you are running the risk of over heating your motor and doing some serious damage to it with a 31T pinion. Tops would be 18T... TOPS!
01-18-2012, 05:46 AM | #15 |
Quarry Creeper Join Date: Nov 2011 Location: Maryville
I've got the stock motor in my lnc/soon to be lcc, and I'm looking at motors, but can't figure out what to get and what pinion to run. I want some more wheel speed, but not a rock racer. I have a MMP to put in it already, as well. Am I understanding correctly that I should get a lower turned motor and a smaller pinion gear, as well, to keep the motor cool? But, how do I determine if it's going to be faster or not than the stock setup with a 35T and 20 tooth pinion? Chris |
01-19-2012, 08:45 PM | #16 |
Rock Crawler Join Date: Sep 2011 Location: Richfield
If you know the motor rpms or Kv at a given voltage, you can do the math for your set-up with any motor, gear, tire or battery combo to find MPH. If you figure out your current set-up MPH, then change formulas for pinion, motor, battery etc you will see if changes make it "faster" or "slower". voltage X kv / overall reduction ("FDR" Final Drive Ratio) X tire circumference X 60 / 12 / 5280 = MPH If you dont have a manual, go to losi site and download. They have a chart for the FDR for the LCC / LNC with different pinion gears. With this formula, you can sit with a calculator and get a feel for what each change will get you. Here is a good thread from our local club forum which illustrates what I just said. MPH is discussed in post #2 Caveman's motor/watt/amp and junk discussion thread. - Nostr Forums |
01-19-2012, 09:04 PM | #17 |
Thanks...
01-19-2012, 09:58 PM | #18 |
Pebble Pounder Join Date: Dec 2011 Location: Ridgecrest, CA
Just be aware that the Gear Ratio Chart in the LNC manual is in error. They quote a final drive ratio of 62.51 using a 20 tooth pinion. In reality, it is closer to 102 to one. I don't know if the chart in the LCC manual is in error or not. Jerry
01-20-2012, 07:02 AM | #19 |
I think it would be cool if one of the gurus made a chart for the lcc with lots of common motoring pinion combos for us newbies...lol. Chris |
13.5T brushless pinion - Similar Threads | ||||
need help properly mesh pinion and spur also suggestions on brushless setup | bro_die | Axial SCX-10 | 0 | 02-22-2011 04:55 AM |
Going Brushless with my LNC what pinion ? | theupsguy | Newbie General | 4 | 05-04-2010 10:59 PM |
pinion size/18.5 brushless. | zignzag | Team Losi Comp Crawler | 7 | 04-11-2010 02:23 PM |
