04-28-2012, 08:57 AM | #1 |
Pebble Pounder Join Date: Mar 2012 Location: red bluff
| grease? oil? or nothing?
In the lcc tranny there are a hand full of bearings and in my opinion quit a bit of friction on some of those parts so I tolk it all apart and let the bearing soak in all purpose oil cleaned them up and greased all the moving parts in the tranny just not the gears...... is any one greasing or oiling there tranny? Thank you ryno
04-28-2012, 09:22 AM | #2 |
Quarry Creeper Join Date: Oct 2011 Location: Shirley
| Re: grease? oil? or nothing?
a light coat of thin oil on the forks where the dig plates ride. and on the fork shafts. try and keep the dig plates themselves dry. and run the gears dry. will help keep crud from sticking to them and causing excessive wear. i know petes phoenix thread is long, but just about every aspect of these rigs has been covered in it, and then some. and it was all discussed in depth. theres extensive lubrication and maintenance info in there if ya take the time to work your way through it.
04-28-2012, 10:05 AM | #3 |
And Pete's thread isn't the only one. Yes, lightweight, thin oil like a 3 n 1 or bearing oil thin, on the forks where the dig plates ride is all you need. |
04-28-2012, 01:06 PM | #4 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
the secret for long threads is right at the top of the page, click search this thread, enter the keywords of what you are looking for, and it'll poop out posts regarding the topic and eeepee's thread goes deeply in depth as well, i've learned a lot of things from that thread, most important being how to successfully run a brushed motor.
grease? oil? or nothing? - Similar Threads | ||||
To grease or not to grease?...... that is my question | 1111Mavrick | Axial Wraith | 10 | 02-08-2012 06:05 AM |
What lube/oil/grease do you use for your rig? | gymjunkie23 | General Crawlers | 20 | 10-26-2010 05:30 PM |
best shock oil and gear oil | j4k3 | Axial SCX-10 | 2 | 07-26-2010 12:48 PM |
grease or not to grease that's the question? | philgoods9 | Axial AX-10 Scorpion | 2 | 04-28-2010 07:52 PM |
