12-25-2012, 11:18 AM | #1 |
Quarry Creeper Join Date: Mar 2010 Location: Los Angeles
| Christmas Sweetness - Tekin Roc 412
Treated myself to an early Christmas present. Tekin Roc 412 2300kv motor on 2S w/ 18 tooth pinion. Coming from a Holmes Hobbies 45t motor w/ 20 tooth pinion. Definitely an awesome upgrade. A lot more wheel speed and more low end torque. Put two battery's through it doing some testing on my local rock garden and am very impressed. Definitely opens up many new lines. Looking forward to a friendly comp this Friday. |
12-25-2012, 01:24 PM | #2 |
Rock Crawler Join Date: May 2011 Location: SoCal
| Re: Christmas Sweetness - Tekin Roc 412
"Friendly comp"? I thought you were coming up here.
12-25-2012, 01:43 PM | #3 |
| Re: Christmas Sweetness - Tekin Roc 412 Funny! I've been warned that there will not be a repeat of what happened last time we were up.
01-01-2013, 01:01 PM | #4 |
Newbie Join Date: Jan 2013 Location: Chandler
How you like it? I'm about to order the same motor on a 3s. Curious how the huge rotor plays out.
01-01-2013, 01:27 PM | #5 |
| Re: Christmas Sweetness - Tekin Roc 412 |
01-01-2013, 01:45 PM | #6 |
How is it from 0 RPM to an slow crawl? I've read about some jumpiness and low RPM resolution issues. I'm running a MMP as well, but you can only dial out so much. Think you could get away with the 3100 to tame the torque down slightly? Thanks!
01-01-2013, 05:47 PM | #7 |
| Re: Christmas Sweetness - Tekin Roc 412 I had some jitters in the beginning. First I found out that the MMP needs to be set to "Sensored Only" mode, not "Smart Sense." This programming change eliminated 90% of the jitters. The rest was eliminated when I put the BEC back in. Seems like the motor draw was perhaps causing low voltage to the receiver. I not sure of that diagnosis. All I know is the BEC cured the problem.
Christmas Sweetness - Tekin Roc 412 - Similar Threads | ||||
World release, Tekin ROC 412 | jetboat | Electronics | 431 | 03-19-2014 03:25 PM |
TEKIN Christmas Giveaway! - ROC 412 Crawler Motors | Ty@Tekin | Electronics | 598 | 10-21-2013 07:30 AM |
Tekin ROC 412 motors in stock! | RPP Hobby | RPP Hobby | 0 | 12-24-2012 10:48 PM |
Tekin ROC 412????? | Soulo747 | Electronics | 1 | 12-09-2012 05:18 PM |
B-ROC Toys for Christmas Comp 12-05-09 LRC | shag | Competitions | 159 | 12-10-2009 02:08 PM |
