Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: 4 wheel steer
Old 04-12-2015, 08:47 PM   #1
Default 4 wheel steer
I just ordered the 4ws for my night crawler.
Why does so few people run this?
looks like it opens a entire new world of opportunities
crashtestheli is offline   Reply With Quote
Old 04-13-2015, 11:44 AM   #2
Default Re: 4 wheel steer
Not popular probably because of competition classes. 4WS is not compatible with most of the popular 2.2 classes.
Secondly because it adds a lot of rear axle weight which hurts climbs, which are critical to comping.
I've put rear steer on my recreational crawler, and it is very awesome. Combined with the comp crawler DIG, impossible lines are very doable now. Less bashing, more crawling. Totally my style. Way fun.
Behemoth60 is offline   Reply With Quote
Old 04-13-2015, 01:16 PM   #3
nice - that's what I wanted to here. This is my camping crawler - no comps around here. - hence the "night" crawler
I want to give it the ability to go anywhere/ climb anything. - just for shear fun.
Old 08-15-2016, 09:40 PM   #4
I'd like to add rear steering to mine. What is all needed?
Vwfreak is offline   Reply With Quote
Old 08-16-2016, 10:14 AM   #5
The exact same as your front axle. Losi makes a rear steer kit.
84yoda is offline   Reply With Quote
Old 08-18-2016, 07:28 PM   #6
If your just crawling for fun than definitely add 4ws and the dig is the way to go!
Jeff Jenkins sr is offline   Reply With Quote
Old 08-25-2016, 04:40 AM   #7
I imagine you can use a front axle from a lost night crawler?
remington7 is offline   Reply With Quote
Old 08-25-2016, 03:36 PM   #8
Tib
You just need to order the *LOSB2046 Rear Steering Kit: NCR, CCR
I installed it on mine, it's a fun mod but it has it's limitations. You either have to get a reversed servo or open one up and reverse it internally. I didn't want to run a reverser cable so I opened up the servo and reversed it. You'll need a splitter for the servo connection also. At time's I want to remove it, other times it works awesome.
Tib is offline   Reply With Quote
Old 08-25-2016, 06:56 PM   #9
Tib
I forgot to mention depending on your setup you'll have to relocate the esc to another location on the rig.
Old 03-31-2017, 11:15 AM   #10
Default Re: LNC 4 wheel steer
I just purchased the Losi rear steer kit for my LNC 2.0. I now have the kit and the servo, but not finding any instructions anywhere. Anyone know if there is a video or anything written as far as instructions? I am pretty new to all this and although I can look at the front end and figure it out, I wanted to find some info before I started if there is any available.
Thanks ....
OCK913 is offline   Reply With Quote
Old 03-31-2017, 11:17 AM   #11
MODERATOR™
EeePee's Avatar
There ya go. Easy as that. You probably could have been done by now.
EeePee is offline   Reply With Quote
Old 03-31-2017, 02:52 PM   #12
No idea what I'm doing
Thanks ....
You can get the NC manual online:
http://www.horizonhobby.com/pdf/LOSB0104_Manual.pdf
Or you can use the LCC manual:
http://www.losi.com/ProdInfo/Files/C...wlerManual.pdf
Or take apart the front while taking a bunch of pictures, put it back together, flip it around and do it again for the rear.
If you take your time, you'll be fine...it's really a pretty simple operation.
C*H*U*D is offline   Reply With Quote
Old 04-01-2017, 09:39 AM   #13
OK, Probably easy enough to just look at the front setup, I get it ..... but looking at Tibs post above, there is a need to reverse the servo, didnt know about that part. In addition, I have seen videos where the rear steer is switchable to crab walk or tight circle. How is that accomplished?
Old 04-01-2017, 10:15 AM   #14
Your remote. You won't need to reverse the servo if your remote has a mix for 4ws. If your running stock remote, then you'll have to reverse the servo.
Old 04-03-2017, 01:01 PM   #15
For a comp crawler I would expect that you would need a tx/rx set with a third channel for the rear servo, so that you can either steer the rear wheels separately with a toggle button, or toggle between multiple 4WS mixes (opposite, crab, off). I only needed two mixes (opposite and off, using a DX4C) for my rig, so that is as far as I can help you there.
DavidH is offline   Reply With Quote
Old 04-03-2017, 04:37 PM   #16
I rear steered, my NC, along with an LCC dig trans. Controlled it with a Flysky. I never comped, but it was a fun novelty. Kind of impractical for real crawling though. As that's a lot of things to control all at once.
dieselmudder is offline   Reply With Quote
Old 05-28-2017, 10:32 AM   #17
I'm looking at doing this to a Comp Crawler I just picked up. Could you post some pictures of where you mounted the esc?
thanks
66gt350 is offline   Reply With Quote
4 wheel steer - Similar Threads
looking for all wheel steer. crawlerknownothing Losi Micro-Rock Crawler 2 11-23-2010 04:53 PM
4 wheel steer must85 Axial AX-10 Scorpion 5 04-11-2009 03:52 PM
4 wheel steer (+ and -'s) Knoc Newbie General 2 11-11-2006 03:11 AM
4-wheel Steer Jeepernick Newbie General 4 07-17-2006 02:55 PM
4 wheel steer krawler kid General Crawlers 1 03-15-2006 07:09 AM
