12-26-2015, 08:47 PM | #1 |
Newbie Join Date: Dec 2013 Location: roseburg
| New Setup
I broke down and replaced my brushed HH 27 turn with a new brushless setup. I got a 17.5 turn Tekin and a MMP, using a 14 tooth pinion. The wheelspeed is great but I am a little disappointed with the low speed crawling. Not near as smooth as my brushed setup. Is this to be expected? I never had a sensored brushless before and I thought it would be just as good. Actually getting some cogging at very low speeds and at low torque as well. Do I need to do some tweaking on the esc to get better results? Sent from my HTC6525LVW using Tapatalk |
12-27-2015, 06:53 AM | #2 |
Quarry Creeper Join Date: Dec 2009 Location: Strafford, NH
| Re: New Setup
On the MMP you need to make sure that your leads between the ESC and motor are; A goes to A, B goes to B, and C goes to C. Than program for sensored only. If that is how you have it wired up, you may want to take a good look at the sensor cable. I run a 17.5 and 13.5 on both of my LNC with Tekin RS esc, and have good low speed control with no cogging. |
New Setup - Similar Threads | ||||
Is my setup right? CKRC Stage 2 setup - front axle castor | Miller Time | Axial AX-10 Scorpion | 14 | 03-01-2008 12:54 PM |
Clod axle setup VS Shaft setup | jrscycle | Newbie General | 6 | 12-21-2005 09:21 AM |
