11-30-2016, 08:07 PM | #1 |
Newbie Join Date: Nov 2016 Location: Canton
| Scx chassis swap
Ok so I am going to swap my nightcrawler chassis for a scx chassis. Anyone done this before if so how did it go?
11-30-2016, 08:09 PM | #2 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: Scx chassis swap
Hit up nerby149. 149 r/c worx's Team Driver |
11-30-2016, 08:38 PM | #3 | |
Rock Crawler Join Date: Apr 2010 Location: Eastridge Tn.
| Re: Scx chassis swap Quote:
Sent from my HTC One M9 using Tapatalk | |
11-30-2016, 09:09 PM | #4 |
The homebrew chassis and skid world be a good platform for you to build from. 149 r/c worx's Team Driver |
12-01-2016, 08:47 PM | #5 |
149 r/c worx has a skid that will fix you up! 149 r/c worx's Team Driver |
12-02-2016, 09:22 AM | #6 |
RCC Addict Join Date: May 2007 Location: pasadena, tx
i have done that, but i need to finish it. i used the stock scx skid and made a trans adapter from losi to axial. |
12-05-2016, 07:48 PM | #7 |
149 r/c worx team just released a flat skid with no holes in it so you can drill your own for your losi transmission 149 r/c worx's Team Driver |
12-06-2016, 03:00 PM | #8 |
Rock Crawler Join Date: Sep 2011 Location: Richfield
YES! Thats ALL I build! Ive been building Losi Worm based scale crawlers since 2009. IMO, Its the only way to go! Ive got a bunch of threads on RCC. Search GiJoe or Mudd'n Militia and you're sure to find some of my rigs. |
12-07-2016, 02:07 PM | #9 | |
The most versatile setup i've found for a Worm Scaler is this: Losi HD Worm Gears (add the grease port and PACK those axles full of CowRC Udder Butter or a similar high quality Moly Grease). Mamba Max Pro ESC (2 pole) 13.5 Sensored Brushless Motor Night Crawler Transmission w/ Hot Racing Metal Trans Gears Castle 10 amp BEC 4S Lipo Team Losi (hardened) 15T Pinion Additionally, I carry a small can of WD-40 with me at all times. Before every run, i spray the driveshaft and axle CVD's and bearings. You must remember, due to the axles having such a steep ratio, the driveshafts will be spinning at least 5X faster in a Losi than in a comparable Ring & Pinion crawler. Hope this helps! Its a Bulletproof plan! I run my scalers in SORRCA Class 1, 2 and 3, G6, TTC and normal trail riding. It Can Be Done! | |
12-08-2016, 05:07 AM | #10 |
Thank y'all so much. I am new to RC crawling, and what does R&D and the different classes mean
12-08-2016, 05:32 AM | #11 |
Research and development. I run a similar set up in a losi but use dry pft spray so it won't collect so much dirt. 149 r/c worx's Team Driver |
12-28-2016, 10:04 AM | #12 |
Rock Crawler Join Date: Mar 2010 Location: Onalaska
Here is one of 2 mud trucks that I have made using losi and scx-10 chassis married together I know not crawlers! but thought I would show another option that works really good and cheap and easy to do I do move the trans plate to bottom of losi chassis now to just trim edges and drill holes |
12-29-2016, 09:32 AM | #13 |
here one of mine so far. the second pic is one version of an adapter plate i designed and had cut out. i have multiple versions for lcc and lnc transmissions. |
Scx chassis swap - Similar Threads | ||||
scx axle swap q's | diesel kawboy | Vaterra Twin Hammers | 3 | 05-20-2014 12:13 PM |
SCX-10 Axle swap | camino ty | Axial SCX-10 | 3 | 04-16-2012 06:50 PM |
AX to SCX swap underway. | ridepate | Axial SCX-10 | 4 | 11-29-2011 06:30 PM |
Chassis Swap-Around | Kyle_A | HPI Wheely King | 30 | 03-31-2008 11:12 AM |
chassis swap!! | throttleboy | Tamiya Clod Buster | 3 | 02-26-2007 06:39 AM |
