04-27-2013, 12:00 AM | #1 |
Rock Stacker Join Date: Oct 2010 Location: Birmingham
| PL TSL Foams
what is everyone opinion for the best foam to run in the 2.2 PL TSLs? theyre g8 with memory foams right now but have been thinking about swapping to maybe CI or something. the rig weight is right around 4 lbs so its pretty light, just looking to see whats on the greener side of the fence since i havent played with foams much! |
04-28-2013, 08:28 AM | #2 |
| Re: PL TSL Foams
I tried those then swapped out for a set of old CI foams. They were unused, but their old open cell inner and outer. I don't have the new ones, but it says they are closed cell now.
04-28-2013, 08:34 AM | #3 |
Rock Crawler Join Date: Aug 2011 Location: Kingsland, GA.
| Re: PL TSL Foams
The new CI foams will bring any tire to life. Best upgrade i did to my rig.
04-28-2013, 03:36 PM | #4 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
| Re: PL TSL Foams
cant stand the memory foam that came with my 1.9 ended up taking the foams out of my stock tires much better every time i hit a rock with the memory foam the tire took like 30 seconds to go back to normal
04-29-2013, 07:44 AM | #5 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
| Re: PL TSL Foams
Is this for a comp rig or scaler??? I have those tires on my Wraith with CI 5.5 double deuce, medium front firm rear. For a rig around 4 lbs you may want to go with a soft front and medium rear. |
04-29-2013, 10:06 PM | #6 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
| Re: PL TSL Foams
I am running 5.25" CI foams with wide inners and medium outers. Fit and perform perfectly. The inner width will depend on how wide of a wheel you are using. My wheels are 1.25" wide.
05-01-2013, 12:13 AM | #7 |
Hmm. Ci definitely sounds like the way to go. Gotta figure out which one now lol Thanks for the input though guys. Keep it coming! |
05-01-2013, 04:42 AM | #8 |
Quarry Creeper Join Date: Dec 2010 Location: Franklin, Va
| Re: PL TSL Foams
I'm in the exact same predicament! I have 1.9s and need to figure this out
PL TSL Foams - Similar Threads | ||||
2.2 TSL foams | tj on 37s | Tires and Wheels | 7 | 10-06-2012 08:19 AM |
2.2 tsl foams | square68 | Tires and Wheels | 13 | 10-25-2011 07:11 PM |
1.9 Flat iron foams in tsl boggers | Blaine | Tires and Wheels | 7 | 03-29-2011 03:52 AM |
foams for 1.9 Super Swamper TSL/SX | drzjohn | Tires and Wheels | 1 | 12-19-2010 12:00 PM |
