05-20-2013, 06:55 AM | #1 |
Newbie Join Date: Feb 2013 Location: Monroe, MI
| Axial bead lock screw troubles?
I just picked up a used set of Axial beadlocks 2.2 with Losi Rock Claws and wrap around wheel weights and plan on putting them on my SCX10 Rubicon, I searched and think that Pro-Line PRO-2 Front Clamping Hexes for a pede will take up the offset so they will work. I don't plan on trying with the weights first as this set up is 3 oz heavier than the stk set up, and I am not a scaler or comp, just fun for me and the kids. All the screws have stripped heads and I think they are 2.5mm x 25mm? I was thinking of trying 2.5mm socket heads but they stick out a little, would this cause hang ups? What screw should I use? Are these stock xr 10 wheels? I bought these from someone that bought a box of stuff from his lhs. I also thought about using 3mm flat heads, they stick out a mm or 2 but have deeper slot for hex keys. Any help appreciated, I did search first but saw many different sizes talked about and am not sure exactly what wheels I have. 1 |
05-20-2013, 07:16 AM | #2 |
Quarry Creeper Join Date: Apr 2013 Location: SE PA
| Re: Axial bead lock screw troubles?
those look like a set of the wheels that come with the xr10. I bought a set of them from someones xr10 kit. all new screws and I ended up stripping the heads of about 2 per wheel. I'd be interested in finding a good replacement for them.
05-20-2013, 07:16 AM | #3 |
Quarry Creeper Join Date: Nov 2012 Location: Wapella
Not sure on the size screw. I'd take one to the local hardware store they usually have a gauge there to figure out sizes and then look for a button head in that size. I'd also take a wheel to try the screw in just to make sure the holes aren't stripped.
05-20-2013, 08:34 AM | #4 |
Have not found a hardware store that carries 2.5mm or 3mm. Lowes/Homedepot smallest is 4mm.
05-20-2013, 08:36 AM | #5 |
Quarry Creeper Join Date: Dec 2010 Location: Alberta
I bought stainless steel 4/40 1" counter sunk flat top allen head screws for my XR10 wheels. Worked great.
Axial bead lock screw troubles? - Similar Threads | ||||
stock bead lock screw size? | concretejungle | Team Losi Comp Crawler | 9 | 02-21-2011 06:16 PM |
bead lock screws...axial | Deezul | Tires and Wheels | 8 | 11-19-2008 02:06 PM |
will an axial bead lock work | jwilli2213 | Chit Chat | 4 | 01-08-2008 07:17 AM |
