![]() | #1 |
Tire&Foam Extraordinaire ![]() Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
| ![]() I am notoriously critical of Axial for their line of ready to replace vehicles. However, they do design and make some great parts. And to be fair, when Axial does something right, they deserve their respect for it. I bought these Axial Yeti XL wheels & tires on ebay and paid full price. I needed them for foam design purposes. I was totally surprised when I received them. ![]() 3.8" x 2.375" ![]() 2.9" x 7.25" ![]() ![]() Comparison Photo; 3.8"; 2.2" & 1.9" Axial BFG Krawler Versions: ![]() ![]() |
![]() | #2 |
| ![]() There are several reasons why I am excited about this new wheel & tire combo by Axial. 1. Compared to the MT wheels we narrowed down in the past, the raceline wheel is fairly light @ 3 ounces: ![]() 2. I think the 3.8" Raceline wheel is a viable option for entry level super class wheels. No one has addressed it and made an affordable semi narrow wheel. This wheel could be still narrowed by the end user if desired, but it will work as is. 3. Mega Truck build wheels ![]() |
![]() | #3 |
| ![]() The 3.8" BFG Krawler Tire feels great in the R35 compound. Weight: ![]() 1. This tire comes at a perfect time! Pro-Line had already discontinued the Moab XL, but the Trencher was also discontinued recently. You can buy them in a Traxxas bead style, but that will not work on Rock Crawlers. Cut N Shut'rs were SOL. No we have an even better replacement ![]() Inside view: ![]() Here is the tire mounted on a 1.5" Narrowed Tech 5 Wheel for an affordable super tire option: ![]() ![]() ![]() |
![]() | #4 |
Awesome write up! I've spent some time, on and off over the last week an a half - 2 weeks, looking for the right tire to use sidewall's off of, for my next cut n shut tire. Thanks for doing the homework for us! |
![]() | #5 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
questions for you sir, when you narrow a wheel such as that one, do you take meat out of the middle of the wheel and glue the two beads back together. and if that is what you do, what are you methods for keeping them together. i have narrowed wheels in the past and they always came apart after gluing them together. |
![]() | #6 |
I need something to put a set of these on.
![]() | #7 | ||
| ![]() Quote:
![]() Quote:
Twin Force Axles would be perfect for them ![]() | ||
![]() | #8 |
Quarry Creeper Join Date: Oct 2011 Location: New Mexico
Can you tell us what the overall width (#.##) of that tire is on that 1.5" tech5?
![]() | #9 |
I joined the Band! Join Date: May 2006 Location: Between a rock and a hard spot!
FEATURES Trail/Comp sticky R35 compound INCLUDES Two 3.8" BF Goodrich T/A Tires with Black Foam Inserts SPECIFICATIONS Width: 2.9" (74mm) Outer Diameter: 7.25" (184mm) ![]() I'm using a rc4wd Dick Cepek Bead lock wheels to mount the BFG Krawler to It isn't as narrow but what I need is the 1'' offset that they offer. My build is a 1/5 Losi DBXL cage and body that is wide and I need the width that they offer. Also the 22'' wheel base keeps it looking scale and that is the reason I'm a fan of theses tires They work for a lot of reasons for a lot of people. I just can't believe that it took this long to get a 3.8 scale tire thats worth looking at that also offers performance. rc4wd has The Cepek MTZ but it is costly and fairly new also. I like the Dia. of the krawlers more also. Specifications: Plastic Injection Molded Scale Wheel Nut Cover with Dick Cepek Logo Fits 17mm Hex (Revo / Summit) Unmatched Detail Wheel Size: 3.8in OD: 3.66in / 93mm Width: 2.93in / 74.5mm Center Hole OD: 0.47in / 12mm Negative Offset: 1.02in / 26mm Each Weight: 9.67oz / 274g ![]() Last edited by twissted; 12-06-2014 at 04:50 PM. |
![]() | #10 |
The RC4WD Cepek Beadlocks are the so easy to narrow that it's just a matter of cutting and tapping holes for the screws to hold the ring back on. That's it!!! Nothing to glue untill you narrow the center ring that locks the bead so it doesn't really matter if it is welded back together all that strong. Plastic can be a bear some times but these look simple to do. But if you had a leath it would even be better because then you would just turn down the center ring. ![]() ![]() ![]() ![]() The off set is going to be the problem unless you a have narrow axles. Last edited by twissted; 12-06-2014 at 05:34 PM. |
![]() | #11 |
![]() | #12 |
![]() | #13 |
| ![]() Here we go: ![]() ![]() Size comparison: ![]() |
![]() | #14 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
C.I. Do you have any videos of this tire and foam setup running? It would be nice to see the handling characteristics of this nice setup. Thank you |
![]() | #15 | |
| ![]() Quote:
No. I do not own a Yeti XL, but here is a Traxxas E Revo on 6S Lipo, on the ICE, with a Castle Creations MMM & 2200KV. The principles and physics are the same in terms of vehicle weight and size. C.I.'s Traxxas E-Revo test truck for Deuce's Wild Monster Truck Foams, ProLine Bad Lands MT Tires glued to Traxxas rims. The rear axle has a JB Welded / Locked hardened steel rear diff, runs on 6S Lipo (24Volts); Castle Creations ESC & Motor; RRP steel 65T spur gear; Hitec servo, no sway bars; RPM arms, and many other aluminum upgrades. The truck is work to drive with the locked rear axle and 6S and regularly breaks parts. The video was filmed on a rare snow day in East Texas on 3.3.2014. If 24 volts was ever going to explode a high rpm spinning tire, this would be it. Watch the tires and foams. Very little growth at full RPM free spinning on ice! | |
![]() | #16 |
I had the opportunity to test this set up today in a 18 pound, 1:5 HPI Savage with The Crawler Store chassis kit. Castle Mamba Monster ESC Castle 2200KV motor 2x 3S Lipo = 24volts :-D Holmes Hobbies Servo Futaba TX & RX Pics: ![]() ![]() ![]() ..Uploaded from the lab @ the C.I. Compound... |
![]() | #17 |
| ![]() A short video via YouTube Capture; iPhone 4S; CI Compound; testing the Axial Yeti XL wheels, R35 3.8" Krawler TA tires; with Crawler Innovations Deuces Wild 3.8" XL tire foams. Test vehicle is a 1:5 HPI Savage with The Crawler Store 1:5 chassis kit. 24volts total, castle Monster Mamba and Castle 2200 KV motor, and it weighs 18 pounds RTR. |
![]() | #18 |
Wow, that is a massive rig. Looks like the wheels/tires and foams did good.
![]() | #19 |
Newbie Join Date: Dec 2016 Location: boone ,nc
Hey i have to stock rtr bf goodrich krawler on yeti xl and even on 4s lipo they about slung off and wobbled crazy at higher speed, would the foams that are cwr-3009 meant for up to 7.50 tall tire cause it to handle better and alot less swelling? I could use gorilla tape but still yet mine are spongy. What you think? Im also changing diff fluid around to 200k front and 500k rear
![]() | #20 | |
| ![]() Quote:
Deuce's Wild part# CWR-3009 You will notice a huge difference with the CI closed cell foam. I don't think you will need the duct tape or gorilla tape. CI does not use any tape inside of our tires. We also run the big rc's on 6S. | |
