12-16-2014, 04:07 PM | #1 |
Newbie Join Date: Dec 2014 Location: Oneida
| Firmer Foam for 1.9 Tires
Hey guys, I am currently using a set of Rock Crusher XT 1.9's on a LEGO 42030 wheel loader but the stock foam is too soft. I ordered a pair of foams from Crawler Innovations but there is still an air gap and they do not fill the tire. This causes the tire to look flat although not as bad as before. Single Stage Closed Cell for 1.9 Tires 4.25" - 4.19" T Unlike with a crawler I need the tires to be firm. The rear of the loader is where most of the weight is located and I'm having a difficult time finding something to use as an insert. |
12-16-2014, 04:35 PM | #2 |
| Re: Firmer Foam for 1.9 Tires
I would order the next size larger then. this is the next size larger, made for a 4.45" tire Single Stage Closed Cell for 1.9 Pit Bull Rock Beast are you sure there is an air gap? or is the rigs weight compressing the foam? |
12-17-2014, 06:12 PM | #3 |
If I squeeze the tire I can feel where the closed cell foam insert is. There is a 1/8 inch gap between the top of the foam and the inside of the tire. The CI Pit Bull inserts have the right sidewall thickness but the width is a concern. Would a 2.2 foam(like at rc4wd) be an option? The rim cutout seems to be the same size. |
Firmer Foam for 1.9 Tires - Similar Threads | ||||
Micro tires, foam or no foam??? | 89redranger | Losi Micro-Rock Crawler | 9 | 04-19-2013 04:35 PM |
firmer springs for proline scaler powerstroke shocks? | jebster | General Scale Talk | 9 | 06-01-2012 09:06 AM |
Stock tires, foam or no foam... | warfish | Losi Micro-Rock Crawler | 8 | 04-15-2011 12:33 PM |
Need firmer foams for thrashers | pardonmyn00b | Tires and Wheels | 2 | 09-23-2009 12:31 PM |
do i trim the memory foam like i did the reg foam with the stock tires? | bmuenter | Tires and Wheels | 8 | 08-15-2008 08:59 PM |
