06-15-2015, 05:54 PM | #1 |
Newbie Join Date: Jun 2015 Location: liberty
| tire size
can a 2.2 wheel and tire fit a stock scx10 deadbolt?
06-15-2015, 06:49 PM | #2 |
Pebble Pounder Join Date: Oct 2014 Location: bellville
| Re: tire size
Yes and No.
06-15-2015, 06:55 PM | #3 |
| Re: tire size
You will have to find a short tire. Rc4wd Mud Slingers 4.88 inch dia. King 100mm shocks. Trim the fenders. |
06-16-2015, 08:27 AM | #4 |
| Re: tire size
oh ok so ill need to upgrade the shocks to fit 2.2 wheels and tires?
06-16-2015, 01:00 PM | #5 |
Quarry Creeper Join Date: Oct 2008 Location: Finland
| Re: tire size
Depends on the wheels and tyres. If you get small 2.2 tyres and wheels that widen the track then you probably won't have to do anything. I suggest you get the wheels and tyres you like and then see if they require any modification to fit. One way to fit huge tyres is to use the AR60 axles that are fitted to the Wraith and Ridgecrest. They are wider and will provide more stability and clearance for big rubber. What ever you do remember that a taller vehicle is more prone to roll over. Last edited by Scrap; 06-16-2015 at 01:01 PM. Reason: Just for shiggles |
06-16-2015, 05:17 PM | #6 | |
| Re: tire size Quote:
Pitbull Rock Beast II 5.75 tall Last edited by Reddog95; 06-16-2015 at 05:19 PM. | |
06-20-2015, 02:26 PM | #7 |
Quarry Creeper Join Date: Aug 2013 Location: Wijnandsrade, NL
| Re: tire size
All will depend on which 2.2's you plan on driving. The smallest 2.2's (Prolin Flat Irons, which is a very underestimated tire by the way) will fill. But a small bodylift is adviseble. Bigger 2.2's will hit your body on turn while the suspension in compressed.
tire size - Similar Threads | ||||
tire size | mitchr97 | Losi Micro-Rock Crawler | 7 | 11-16-2012 03:13 PM |
tire size | lawndog | 1.9 Scale Rigs | 1 | 01-05-2011 07:54 PM |
tire size | slowride1 | Losi Mini-Rock Crawler | 2 | 09-28-2009 12:27 PM |
