12-07-2015, 02:00 PM | #1 |
Newbie Join Date: Dec 2015 Location: Philly
| 1.9 tire recommendations taller than 4.7
expecting my new 1.9 beadlocks...replacing the stock bfg 1.9 x 4.7 on my CRC edition SCX10 rubicon. So many choices....but doesn't seem like there is are many 1.9 tires taller than a 4.7. If you know any please suggest, thanks! |
12-07-2015, 02:13 PM | #2 |
| Re: 1.9 tire recommendations taller than 4.7
There are lots of options that are 4.75 inches but not many if you want to go beyond that. Not exactly scale but 4.9 inches tall Ruptures - 1.9 |
12-07-2015, 02:13 PM | #3 |
The best 1.9 tires I've used are the Pit Bull Growlers and the ProLine TSL XL. The Ottsix Voodoo KLRs are another popular choice, but I haven't tried them. |
12-07-2015, 02:24 PM | #4 | |
| Re: 1.9 tire recommendations taller than 4.7 Quote:
12-07-2015, 02:28 PM | #5 |
Joto nailed it IMO.
12-07-2015, 02:32 PM | #6 | |
more scale look....wish they were over 4.8 and closer to 4.9 decisions, decisions, decisions Last edited by 3MTA3; 12-07-2015 at 02:34 PM. | |
12-07-2015, 03:37 PM | #7 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
To be fully honest, your CRC already comes with a fantastic set of tires. They are easily overlooked because stock tires tend to be terrible and the BFGs are stock tires. However, my suggestion to you would be to just buy new foams instead and keep the BFGs. I have over a year on mine...great all around tire and even better in the rocks. Also going too tall hurts your center of gravity...id rather keep it fairly low and loose some ground clearance, than be higher up and roll over all the time. I run Crawler Innovations single stage foams for the Mad Beast in my BFGs....give the tire and foam some break in time and then you will really notice a difference, especially in sidehilling/off camber. Plenty of other good tire options available though. |
12-07-2015, 05:37 PM | #8 |
4.75" is about the limit for 1.9s, unless you want to make your own. Lots of good options in this range though.. I like the JConcepts Scorpios and Proline tsl-sx XL a lot as well.
12-07-2015, 06:25 PM | #9 |
If you want bigger than 4.75 go 2.2 wheels, lots of options
12-07-2015, 07:02 PM | #10 |
Quarry Creeper Join Date: Nov 2013 Location: Omaha
If you wanna get through some sticky mud often, TSL. For any other kinda trailing and crawling, Baja claws, iroks or KLRs.
12-07-2015, 08:02 PM | #11 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
Growlers for height and bad ass KLR for bad ass |
12-07-2015, 09:39 PM | #12 |
Sorry, I did forget about the growlers and the rock beasts. The growlers, iroks and Baja claws will ball up quickly in sticky mud though.
12-08-2015, 03:09 PM | #13 | |
12-08-2015, 04:02 PM | #14 | |
RCC Addict Join Date: Aug 2005 Location: Oceano, CA
12-08-2015, 05:36 PM | #15 |
I have had my growlers packed full of mud/loose dirt and they still are unstoppable. Give the throttle a little blirp and they are clean. I am learning that less aggressive tread pattern tires make for a more precise handling rig.
12-08-2015, 07:52 PM | #16 |
| Re: 1.9 tire recommendations taller than 4.7 |
12-08-2015, 08:26 PM | #17 |
Yep bigger wiser spaced lugs always makes for more wandering and yes growlers do clean out under power
12-10-2015, 02:31 PM | #18 |
Quarry Creeper Join Date: Nov 2007 Location: Orygun
The RC4WD Compasses are tall tire, not extremely aggressive, and work really well with 4.5" Lil' Novas.
12-11-2015, 07:34 AM | #19 |
The KLR is 4.75 and mean as hell |
12-11-2015, 08:27 AM | #20 |
RCC Addict Join Date: Dec 2009 Location: Laceys Spring, Alabama
1.9 tire recommendations taller than 4.7 - Similar Threads | ||||
Tire Recommendations | BJoe | 1:1 Full Size Vehicles | 15 | 04-13-2015 07:19 PM |
Anyone out there want a taller 1.9 tire? | Racer4Life | Tires and Wheels | 41 | 11-01-2010 06:41 PM |
i need a taller 2.2 tire!!! | IWantATurbo | Tires and Wheels | 45 | 07-10-2010 12:35 PM |
