03-24-2017, 04:19 PM | #1 |
Newbie Join Date: May 2015 Location: West Monroe
| Putting weights in micro tires.
What is the best way to get massive weight in 1.0 micro tries/wheels? I want to get it HEAVY!!! Since the wheel speed is slow I think a lot of weight will give me extra traction.... Ideas? |
03-24-2017, 04:24 PM | #2 |
Quarry Creeper Join Date: Dec 2013 Location: Pevely
| Re: Putting weights in micro tires.
Fill tire with bb's then mount. I think that I mounted one side to the beadlock then put bb's in and put the second ring on the wheel. all of your weight will always be at the lowest point and it has worked well in my sumo and trail trekker.
03-24-2017, 04:30 PM | #3 |
I have internal beadlocks......
03-24-2017, 04:44 PM | #4 |
There has to be a trick to it. Check in the micro crawler section.
03-24-2017, 05:03 PM | #5 |
Yeah. I'll give that a shot... Sent from my iPhone using Tapatalk |
03-24-2017, 05:18 PM | #6 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
I've tried BBs In the past, but I've gotten more weight by wrapping solder around the wheel then mount the tires. Also with the BBs I've found they sometimes move when you don't want then to move. BTW be prepared for the stock servo to die especially if you have a Losi. The MG90 and MG90s are inexpensive replacements Sent from my Nexus 6P using Tapatalk |
03-24-2017, 05:22 PM | #7 |
It is upgraded everywhere. It the motor and tires..... hitec 65mg, aluminum links..... just need more weight. Sent from my iPhone using Tapatalk |
Putting weights in micro tires. - Similar Threads | ||||
putting tires on beadlock rims, help! | sfar785 | Newbie General | 0 | 03-28-2009 09:54 PM |
Putting holes in my tires | arcticjeff | Newbie General | 10 | 02-11-2009 10:46 AM |
