04-15-2018, 11:28 AM | #1 |
Quarry Creeper Join Date: Sep 2017 Location: UK
| Any idea on how to fix this...
Well I have these Titus pro-line wheels that have decided to round off the hex. I got them 2nd hand when I was more of a noob than I am now...so didn't think to check...ah well learn from our mistakes... Can I get separate bits...or is it worth whacking a hex in there and then melting it on? Or just get new wheels.... Your thoughts? Sent from my SM-G935F using Tapatalk |
04-15-2018, 11:39 AM | #2 |
| Re: Any idea on how to fix this...
Get new wheels
04-15-2018, 11:40 AM | #3 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
I used to run nitro stadium trucks with plastic wheels... glued up and thrashed a lot of 'em over the years, I would plan to replace them. You could also grab some old hexes that you don't care about and JB Weld them in but I wouldn't count on that lasting indefinitely. If you go that route, I would suggest using something like an old axle or similar to center the hexes as best you can while everything cures. I think that melting the plastic is going to cause potential distortion of the wheel and subsequent cracking of the material. If you can afford 'em, I'd just replace altogether and assuming that the tires have any life left, maybe try to salvage them ( de-bonding/ deactivating the CA). Probably better suggestions out there but just my .02 cents.
04-15-2018, 12:53 PM | #4 |
Thanks guys, think I will just scrap them, shame really as they hold a bead really well.
04-15-2018, 01:27 PM | #5 |
I'd just CA glue a hex in there and run it. If you want a fancier bandaid, you can drill a small hole the both the wheel and hex (edit: off center, running left-right when mounted to the car), then screw a set screw through both of them, then your hex is salvageable. Plastic beadlocks are CHEAP on everybody's favorite auction site.
Any idea on how to fix this... - Similar Threads | ||||
IS there anyway to fix this? | Markeje | Paint and Body | 17 | 04-30-2014 12:54 PM |
CVD fix idea | fwilly | Team Losi Comp Crawler | 12 | 06-06-2009 10:26 PM |
another good idea to fix the Drive shaft Failure | kaho0338 | Axial AX-10 Scorpion | 2 | 12-04-2007 11:31 AM |
Got twisted E-Maxx Shafts? New idea to fix that problem! | Krawlin | Chit Chat | 10 | 09-13-2007 08:16 PM |
Busted my front axle, any idea how I can fix it? | Chuki | General Crawlers | 22 | 02-02-2006 05:40 PM |
