Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Beadlock suggestion for Axial SCX102
Old 04-21-2018, 07:07 PM   #1
Default Beadlock suggestion for Axial SCX102
Hi All,
My name is John...new here. New to crawling but not RC. Question guys. Can you suggest a set of beadlocks that will work with the stock tires on the SCX2. I am reading lots of reviews and watching videos...but honestly I am more confused at this point.
RC4WD looks good...good price for 4...but they seems super tricky to install. SSD looks great, but super $$.
Any help would be great.
Cheers
John
chefjness is offline   Reply With Quote
Old 04-21-2018, 07:31 PM   #2
Default Re: Beadlock suggestion for Axial SCX102
I have a couple sets of RC4WD beadlocks. The first set was very difficult to install 1.9" Pitbull Rock Beast 2 tires on. The second set wasn't as bad with 1.55" Pitbull Growlers. That set of wheels did come with 2 longer screws, though. You use the longer screws to start the installation, then swap them out once you get the other screws tightened down. I also like the G-Made metal beadlocks. They're priced well, and they were a little bit easier to assemble with 1.9" Rock Beast 2s.
aver3 is offline   Reply With Quote
Old 04-21-2018, 07:38 PM   #3
Thanks Aver! I will look at these. Do you know if your suggestions will work with the stock Axial scx102 tires. They are replicas of BFGoodrich All Terrian T/A.
Cheers
John
Old 04-21-2018, 08:02 PM   #4
Once you deglue the stock tire they will fit any beadlock you choose as long as the bead is intact.
hillbillyrc is offline   Reply With Quote
Old 04-21-2018, 08:35 PM   #5
Even better
Old 04-22-2018, 12:09 AM   #6
How about $36 for a set of 4 metal beadlocks with tires included? Plastic (which I prefer to keep weight down and not break things) run about $24 with fake Super Swamper tires, or $12 without. I run one set of all plastic and one with just metal rings.
StomperCrawler is offline   Reply With Quote
Old 04-22-2018, 02:57 PM   #7
Moderator
JatoTheRipper's Avatar
GMade plastic or metal beadlocks work well and are good prices.
Old 04-22-2018, 03:04 PM   #8
i used the axial satin beadlocks on my new scx10ii,16.99 for 2,but good rims.
thead is offline   Reply With Quote
Old 04-22-2018, 03:37 PM   #9
Chinese vanquish clones. As good as the original but at 1/4 the price.
Ditchrat is offline   Reply With Quote
Old 04-22-2018, 05:14 PM   #10
thanks for all the help guys.
-John
Old 04-23-2018, 12:25 PM   #11
I put these on my Ascender's stock tires this weekend. So far, so good.
Lafeina Beadlocks $15.99
skinnyj is offline   Reply With Quote
Old 04-23-2018, 01:08 PM   #12
Natedog's Avatar
I have a couple sets of RC4WD beadlocks......That set of wheels did come with 2 longer screws, though. You use the longer screws to start the installation, then swap them out once you get the other screws tightened down.
RC4WD
Old 04-23-2018, 02:14 PM   #13
Originally Posted by Natedog View Post
RC4WD
Those will probably be my next set when I'm feeling a little more "spendy". I'm thinking RC4WD wheels with SS Boggers and CI inserts.
The wheels I got mostly got the nod because they were cheap and "Prime-able".
Also... With RC4WD wheels, don't you need an adapter for 12mm hex use?
Old 04-26-2018, 09:17 PM   #14
My 1.55" wagon wheels use 12mm hexes.
https://store.rc4wd.com/Stamped-Stee...eels_p_36.html
My 1.9" wagon wheels use the pin mount.
https://store.rc4wd.com/6-Lug-Wagon-...te_p_1931.html
Old 04-27-2018, 06:04 AM   #15
I love my steel SSD beadlocks. They're cheaper that the aluminum ones and super easy to mount.
fortyeightjake is offline   Reply With Quote
Old 04-27-2018, 12:42 PM   #16
i run maximizer beadlocks on mine. recently (possibly still going) they had a sale. $5 for two wheels. i stocked up!
goobs is offline   Reply With Quote
Old 04-27-2018, 12:44 PM   #17
Natedog's Avatar
Some do and some don't, have to read the wheel description which they come with.
Old 04-27-2018, 12:47 PM   #18
I tried a set of them a few years ago. Shredded them fairly quickly. I remeber them being inexpensive with a decent appearance. Hope you have better luck then I did.
Old 04-27-2018, 01:10 PM   #19
I run them on a few rigs. one being a losi scaler and it hasnt destroyed the hexes or anything. i have a had a few issues using the stock hardware. i drill and tap the holes for 2-56 and havent had anymore issues.
Old 04-29-2018, 02:32 AM   #20
SSD all the way. I would hold back, save up and look for a good offer. They are not too heavy, not too light and look awesome. And guaranteed an easy install with Axial tires.
Sent from my SM-G930F using Tapatalk
tjohanne is offline   Reply With Quote
Beadlock suggestion for Axial SCX102 - Similar Threads
Help with beadlock suggestion with stock tires..Axial SCX10 2 chefjness Axial AX10 2nd-gen 2 04-22-2018 12:12 AM
For Sales Section Change suggestion. Just a suggestion!! Oscar da Grouch Comments, Suggestions, and Help 25 12-21-2014 08:12 PM
Hey Axial i have a 1.9 suggestion! 2500hdon37s Tires and Wheels 0 04-05-2009 01:37 AM
