01-09-2019, 08:49 AM | #1 |
Quarry Creeper Join Date: Feb 2011 Location: A stupid town
| Incision 1.9 KMC XD229 Machete question
I am looking to get a set of cheap wheels for a RTR scx10.2 I aquired and found these wheels, my question is if they have the same besdlovk ring bolt pattern as the axial 1.9 beadlocks so I could put a set of the gear head beadlock rings on it instead of the normal metal ones it comes with. If anyone has both set of rims to compare or a set of the incisions with the gear head rings laying around to check I'd appreciate it before I order them. Sent from my SM-G965U using Tapatalk |
01-09-2019, 09:03 AM | #2 |
| Re: Incision 1.9 KMC XD229 Machete question
Same bolt pattern on the rings as the Axial wheels. I put a set of Locked Up rings on mine. |
01-09-2019, 09:37 AM | #3 |
Perfect, thank you! Sent from my SM-G965U using Tapatalk |
01-15-2019, 11:07 AM | #4 |
Rock Stacker Join Date: Feb 2015 Location: Netherlands
| Re: Incision 1.9 KMC XD229 Machete question |
01-16-2019, 06:45 AM | #5 |
| Re: Incision 1.9 KMC XD229 Machete question They are great for a plastic wheel and with the Incision aluminum hubs they should hold up to anything. I have swapped about 5-6 different tires onto the wheels without too much issue (really wide tires can be a pain since the wheels are really narrow). These are pretty much the only lightweight scale wheel that has a bolt on hub without resorting to glue. I will be using a set for my next build. |
01-17-2019, 11:35 AM | #6 |
Ok thanks, will check these out |
Incision 1.9 KMC XD229 Machete question - Similar Threads | ||||
In Stock - Incision RC 1.9 KMC XD229 Machete! | RPP Hobby | RPP Hobby | 0 | 03-16-2018 10:01 AM |
Coming Soon - Incision RC1.9 KMC XD229 Machete! | RPP Hobby | RPP Hobby | 0 | 03-13-2018 12:07 PM |
New Vanquish Products KMC 2.2 XD229 Machete Wheels - In Stock! | RPP Hobby | RPP Hobby | 0 | 06-28-2017 11:06 AM |
Incision VDI Question | TheBigRigger122 | Axial Wraith | 5 | 02-29-2016 08:14 AM |
