Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: General question: 1.9" tire on VP 2.2" wheel
Old 02-13-2019, 01:26 PM   #1
Default General question: 1.9" tire on VP 2.2" wheel
I want to use my VP 2.2 vintage wheels VPS06584 (1" wide) on a rig, that needs 1.9" tires. Do you know combinations of tire and rims where this is not possible? I thougjt Bout some RC4WD Wrangler MT/R 4.75" or even 4.19" Which foams you run on this combinations?
ToCrawl is offline   Reply With Quote
Old 02-13-2019, 02:16 PM   #2
Default Re: General question: 1.9" tire on VP 2.2" wheel
Its possible. Some tires are more difficult then others but ive done a few 1.9 tire s on a 2.2 wheel and now a 1.55 tire on a 1.9 rim
Sent from my LG-M703 using Tapatalk
jokersinsanity is offline   Reply With Quote
Old 02-24-2019, 01:28 AM   #3
In usage of my VP Vintage wheels #VPS06584 I fitted RC4WD's MT/R 1.9" 4.75" #Z-T0158 on them.
For monuting I used M3x14 mm. In my setting the zylinder head just fits in.
At the end the 1.9" tires fit on this 1.0" wide wheel quiet well
But won't fit on an 1.2" wide WP-wheel!
See the comparison to an 2.2 #Z-T0153 on VP wheel as well.
Dremel helped me to undo 3 screws with lens head. With a small cut the flat screw driver was able to oben a scre where the hex was wasted.
Lucky that M3x9 fit there as well.
Old 02-24-2019, 06:40 AM   #4
When u strip a 2mm screw try a 5/64 and the 1.5mm is a 1/16 i think
Old 02-24-2019, 09:53 AM   #5
Moderator
JatoTheRipper's Avatar
I don't usually like stretched tires, but the 1.9 MT/Rs look great on those VP 2.2s. I wish VP would make these wheels in 1.9, but when I emailed them they said they sadly have no plans to do so.
General question: 1.9" tire on VP 2.2" wheel - Similar Threads
Crawler Innovations Review- Yeti XL Raceline 3.8" Wheel & 3.8" R35 BFG Krawler Tire Nova's Ark Tires and Wheels 23 01-04-2017 11:37 AM
Tire bounce when going from a 1" to 1.25" wheel mindless Tires and Wheels 4 12-28-2011 06:39 PM
