Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Gmade Beadlocks/Nut Driver
Old 12-25-2019, 07:55 PM   #1
Default Gmade Beadlocks/Nut Driver
Assembled a set of Gmade SR02 Beadlocks. The 'lug nuts' are 2.5mm x 8mm hex bolts. Each pair comes w/ a socket for the 2.5mm bolts driven by a 2.5mm hex driver. I have a Wiha metric nut driver set and tried using one instead of the socket. The 2.5mm is too small while the 3mm is too big.
Anybody know what size nut driver does fit?
Rockin140 is offline   Reply With Quote
Old 12-30-2019, 09:48 AM   #2
Default Re: Gmade Beadlocks/Nut Driver
I use MIP tools and have never had a problem with the SR series of wheels. Is it like that with the adapter that came in both pairs?
mhowzit is offline   Reply With Quote
Old 12-30-2019, 10:21 AM   #3
Moderator
JatoTheRipper's Avatar
I've found the same. I believe they are 2.75mm. Good luck finding that elsewhere.
Old 01-03-2020, 07:09 PM   #4
Measured with caliper the lugs are 3.3mm at the largest point. The adaptor/driver they come with measures 3.5mm
MrBlank is offline   Reply With Quote
Gmade Beadlocks/Nut Driver - Similar Threads
Small Nut Driver Suggestions IronGut Tools, and Procedures 11 05-20-2015 08:16 PM
