10-08-2020, 06:21 PM | #21 | |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
| Re: PL Hyrax vs RC4WD Wrangler, why Hyrax is so slippery? Quote:
Personally I would like to try a narrower version of the 1.75 Proline Krawler. | |
10-10-2020, 12:06 AM | #22 | |
Rock Stacker Join Date: Aug 2020 Location: Finland
| Re: PL Hyrax vs RC4WD Wrangler, why Hyrax is so slippery? https://web.archive.org/web/20170914...tion_rev1.html Quote:
https://www.dropbox.com/s/13qb0l5fn2...ravel.pdf?dl=0 | |
10-10-2020, 05:37 AM | #23 |
Newbie Join Date: Sep 2017 Location: Canada
Hey, that's a good find, some interesting info there.
10-11-2020, 01:38 AM | #24 | |
| Re: PL Hyrax vs RC4WD Wrangler, why Hyrax is so slippery? Indeed it explains a lot, even though it is from 1:1 tyres. I laughed to this, it's very true even with scale crawlers. Quote:
03-25-2021, 06:27 PM | #25 |
Quarry Creeper Join Date: Jan 2016 Location: Southampton
I live in new England and there is always a good natured argument for wide versus pizza cutter tires on 1:1 rigs. My opinion is tall and narrow. I do comp and have Rovers as well as Sadonas and Voo Doo pins. Both narrowed and stock. I also tried a set of Pit Bull XOR and hated them in stock width. I cut about 3/8 of an inch out of the center and they really came alive. I just have to dial in the foams now. I found some of the really soft compounds got slimy feeling if it got over 75 degrees. The thing about cutting off the lugs on the side is all about traction. Not wanting it! Sometimes the lugs will suck you into a hole or crevice. It also let's the tire flex a lot better. I don't know if anyone here has tried shaving the sidewalls on any tires. It does the same thing. Kinda like a drag slick, it let's the sidewalls flex. The thing with shaving the lugs is much like the wide versus narrow thing. Some guys love it some hate it. One of the reasons comp guys play with the foams is to get just the right contact patch. If you talk to some of the comp guys you will find some of them very secretive about the foams they run. With the advent of CI foams it's pretty easy to get a decent set without making them custom, and they will help you decide what product is best for your rig/tire combo. I know a lot of guys that run custom 4 and 5 piece foams, they won't tell you though unless they really trust you. Tires are the last piece between your ride and the rocks and everybody has an opinion on what to run. Sometimes it's all about the looks and sometimes it's all about function. But it's great if you do it right and get both |
05-01-2021, 07:22 AM | #26 |
Pebble Pounder Join Date: Jan 2021 Location: Germantown
One thing that hasn't been mentioned is that the height of the tire effectively changes the gear ratio... Higher gear ratios will spin more than lower gear ratios. Proline advertises the hyrax at 4.75 tall I think, but if they are like the Krawlers I just bought, which are also advertised at 4.75 height, they are right at 5 inches mounted. From 4.19 to 5" OD is about a 19% change in gear ratio, which is also an increase in wheel speed. Last edited by Maxx_Action; 05-01-2021 at 05:21 PM. |
PL Hyrax vs RC4WD Wrangler, why Hyrax is so slippery? - Similar Threads | ||||
New Hyrax or Something Different??? | AnimalHippie | Tires and Wheels | 18 | 04-17-2020 05:07 PM |
