Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: trx4 sport Hyrax foam setup
Old 04-03-2020, 04:38 PM   #1
Default trx4 sport Hyrax foam setup
I recently purchased a Trx4 sport build kit. Loved assembling it. At any rate I purchased some Hyrax tires (which came with foam) as well as the proline dual stage foams. Just curious as to opinions on which to use. I use the rig strictly for slow rock crawling; also the truck is stock with no added weight and I am not using the roof rack. Trying to keep the cg low. One added note, I was impressed how well the stock tires worked which lead me to the above question since the traxxas foam seems much softer the the stock proline foams and even softer yet than the the dual stage. Thank you.
mgruenwald is offline   Reply With Quote
Old 04-03-2020, 04:43 PM   #2
Moderator
JatoTheRipper's Avatar
Default Re: trx4 Hyrax setup
Welcome to the site!
The TRX-4 is a great truck and it's a ton of fun to build - one of the best.
Traxxas tires are great for stock tires, but the Hyrax are better. And I suggest you use the Proline dual stage foams. They are still soft on the outside to allow the tire to conform to the terrain, but the dense, inner foam gives your sidewall some integrity and the tire won't roll over on the edge when side hilling.
Post up a build thread with your truck and share some photos!
Old 04-03-2020, 05:04 PM   #3
Thanks for the reply, although I'm looking for real world experience with my combination.
Old 04-04-2020, 07:18 AM   #4
I mean...he literally gave you real world experience.
"Traxxas tires are great for stock tires, but the Hyrax are better. And I suggest you use the Proline dual stage foams. They are still soft on the outside to allow the tire to conform to the terrain, but the dense, inner foam gives your sidewall some integrity and the tire won't roll over on the edge when side hilling."
Up'n'Over is offline   Reply With Quote
Old 04-04-2020, 08:39 AM   #5
Moderator
I'm confused. I built a TRX-4 Sport kit. I ran it with stock foams and tires. I also ran it with Hyrax tires filled with Proline two stage foams.
I'll take Hyrax with dual stage foams all day.
Here's my evidence.
Old 04-04-2020, 12:17 PM   #6
Default Re: trx4 sport Hyrax foam setup
Your original reply didn't state the experience displayed in the latest reply, (which is what I was actually seeking) thanks.
Old 04-04-2020, 06:04 PM   #7
Thanks for all the info guys! I was looking at a trx4 and also some new tires for my redcat rs10 so this help a lot believe it or not. Also, thats a NICE trx4!
Irontie is offline   Reply With Quote
Old 04-06-2020, 02:33 PM   #8
The stock canyon trails are great tires the foams just tend to breakdown fast. crawler innovation make foams that fit the canyons nicely and will be a big upgrade in performance. my trx was a little on the heavy side, needed stiffer foams because of the weight. now that she been on a diet I went to a medium foam in front and the stiffer ones out back.
fomocosun is offline   Reply With Quote
Old 04-06-2020, 04:14 PM   #9
Hyrax at 4.70 is a massive tyre even bigger than the stock canyons, I've gone down a few mm to pitbull fock beasts at 4.45 with dual stage foams. More scale for sure.
crazee horse is offline   Reply With Quote
Old 04-06-2020, 11:20 PM   #10
I'ma going to steal your wheel/tyre combo dude. SSD's right? Whoo that bronzo looks so pretty!
Here's my evidence.
el_Fernando is offline   Reply With Quote
Old 04-07-2020, 06:09 AM   #11
Moderator
Thank you! Yes, they're SSD Assassin wheels in bronze.
Old 01-13-2021, 12:37 AM   #12
I've used the 1.9 Hyrax tires with the PL 2 stage foams on my TRX4 Defender and my Sport. Which is my class 2 comp truck.
They perform awesomely on both trucks!
Nice and clean, when I first put them on.
Sport at a competition.
Captain Scoundrel is offline   Reply With Quote
trx4 sport Hyrax foam setup - Similar Threads
TRX4 or TRX4 Sport Kit? Help please. m4inbrain Traxxas Crawlers 13 09-01-2021 07:47 AM
TRX4 Sport body on TRX4 Crawler kit chassisc redpeppers Paint and Body 7 09-14-2019 12:59 AM
Trx4 Bronco- Foams for Hyrax preadator compound? AmISam Traxxas TRX-4 10 01-10-2019 10:15 AM
