01-29-2008, 05:20 PM | #1 |
Pebble Pounder Join Date: Apr 2007 Location: Nowhere
| Tuber Building help.
first let me say i have used the search botton many times!! so from what i infer i use 3/16 brake line. what else can i use besides that. for the tranny mount what size aluinum do i use where can i order this stuff online?? thanks for the help!!! |
01-29-2008, 08:59 PM | #2 |
srry for a dd post but any one ???? mapp or bez gas??? link??? |
01-30-2008, 04:31 AM | #3 |
Rock Crawler Join Date: Dec 2005 Location: West Omaha
Mapp gas for sure. Most people use 3/16 brake line as it is cheap and can be purchased at napa. You can also use 1/4 inch brakeline. You could technically use any steel tubing of those sizes. Check out onlinemetal.com they have a bunch. However, they are considerably more expensive than the brake line. I pay about 1 dollar per foot of brake line.
01-30-2008, 07:33 PM | #4 |
I wanna be Dave Join Date: Jun 2007 Location: Canada, eh.
I know the search function has been a little off lately, so I'll let it slip. You're probably not getting a response because there's a sticky at the top of this forum, as well as an article on the main site tech section http://www.rccrawler.com/tuber.htm Read up and you should have most, if not all, of your questions answered! |
01-31-2008, 06:40 PM | #5 |
Rock Crawler Join Date: Sep 2004 Location: South Orange County
oks
01-31-2008, 06:53 PM | #6 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
my trans mounts are made from .064" thick aluminum. p!nK |
02-06-2008, 10:54 AM | #7 |
0.064" thick aluminum? That's what, about 1/16"? Wow, that's skinny! Guess anything thicker would be too hard to bend (assuming you're not using a brake).
02-06-2008, 11:41 AM | #8 |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
~1/16" thick 6061 aluminum is plenty strong in most cases. Jay |
