| | #1 |
| Newbie Join Date: Apr 2005 Location: Orlando, Florida
| Yeah uhm , I'm going to build my own pede main chassi and I just wanna know do you guys think I have to weld/braze the whole thing or can I just hold it all up with nuts and screws? |
| Sponsored Links | |
| | #2 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| I split this post off from where you had it and gave it its' own post if your just making a chassis, something thats flat plates on each side( like how a TXT is or a BULU or a stock TLT,etc.etc) then you can just use nuts and bolts. The only reason you would need to braze it, is if you are making a tube chassis for it |
| | #3 |
| Thnx man! well you see all I'm going to do is rebuild the stock chassi in aluminum, but make the front part look just like the back part so that I can mount the rear part both in the front and the back so that I can have 4wd. Ofcourse I'll make a rectangular cut for the steering servo. Is that good enough or does it need to be more complex? Oh and also r there any esc's that can handle two 55t lathe motors? cause the evx only handles 25-15t I believe it was. Or how do you guys do 4wd(with a motor at each end) with your rigs? |
| | #4 | |
| 2006 2.2 National Champ ![]() Join Date: Dec 2004 Location: Driving my R/C rototiller
As far as the chassis goes, you should be fine with what you're describing. How thick is the material you are going to use for the chassis? Last edited by BENDER; 06-16-2005 at 08:06 PM. | |
| | #5 |
| uhm right now I'm not sure but it's defenately going to be around 5/8"-3/8" and maybe but I don't think so 1/2" caus thats to bulky and heavy, and the material will be aluminum. and maybe a little steel. |
| | #6 |
| So ur saying that I can run two 55t lathe's on a sr? |
| | #7 | |
| | #8 |
| You see if I could post attachments I would show you the pics. of the plans but if you want I could send by e-mail? |
| | #9 | |
| | #10 |
| Ah crap dude look I'm tired I'll post it tomorw |
| | #11 | |
Feel free to e-mail me the pics, I'll check it out for you. If you can post pics here, you'll get more opinions then just mine. | |
| | #12 |
| yeah post up some pics LMFAO at freds' new location |
| | #13 |
| well now that one plan I had is useless because of some little mods if been thiking about but that one is still a possibility, right now I only got a lilbit of the center piece done. wich the center piece is where i'm ganna mount every piece of the main frame on. it's very simple and heavy for it's size i'd say the piece weighs in at about 1/4-1/2 lbs. right now it's useless to post pics. cause tomorow i should be going to homedepot and picking up some rods and aluminum plates for the chassis and i'll prob. have to make skid plates too. so as soon as i start mounting stuff into the center piece i'll start posting pics, for now i gatta think of a way to connect the main chassis to the front and rear using links. and thats why i said i'm probably ganna need to make my own skids to mount the links to and i'm thinking of making my own A-arms too. but anyways here is a pic. ok here u go i re-sized it. Last edited by N00b; 06-17-2005 at 08:44 PM. |
| | #14 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| thats a big *****!! |
| | #15 |
| LOL!! guys it's not that huge it's just the size of the pic. HA HA HA! omg that wuz halarius john! |
| | #16 |
| my computer screen is a 100" widescreen home theater/ computer screen. its about seven foot six inches across on my wall. Last edited by JohnRobHolmes; 06-17-2005 at 08:16 PM. Reason: i measured the pic |
| | #17 |
| Ok now enough with the "off topic" talk here or the administrators will lock it up and delet it. |
| | #18 |
| I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
| One more off topic. Resize the damn pic! That sucker is ****in' huge!! Bigger than even crawler chick's tits! |
| | #19 |
| ok it's been re-sized, anyway I messed up on the center piece man, i jus noticed that one of the sides is longer than the other so i have to get even more plates now and painstakingly bend the damn thing perfect, then i'll braze it if necesary. and aluminum is the best for making chassis right? Last edited by N00b; 06-17-2005 at 09:56 PM. |
| | #20 |
| ahh dont get discouraged.. keep hacking away at it. nobody did their first one exactly perfect except for JIA., but he is one of those perfectionist anyway |
| Thread Tools | |
| Display Modes | |
