03-28-2008, 01:24 PM | #1 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
| BRAZING.. What would you like to know.
As in what would you like for a "How to".. I'm currently working on a "how to make bumpers" But figured I could make somethig a series.. I'll also be recruiting for assistance from other builders as we all have a unique style and would like to present as much of a deversed field as possible, as I feel I could learn a lot from others while I do this. |
03-28-2008, 02:31 PM | #2 |
Quarry Creeper Join Date: Apr 2005 Location: South Jersey (Cherry Hill area)
I would be interested in seeing the mock-up and holding the parts in place stage of a tuber build... also I think this "how to" is a great idea , thanks
03-28-2008, 02:55 PM | #3 |
Thats in the works. I'm going to do an entire build Video. Start to Finish. With explanations as I go. Like I did with the brazing video. |
03-29-2008, 06:22 AM | #4 |
Rock Crawler Join Date: Apr 2006 Location: Eau Claire
Another thing to see would be a demo on how much smoother the Harris safety silv brazes over a flux coated rod maybe??
03-29-2008, 08:30 AM | #5 |
Rock Crawler Join Date: Sep 2004 Location: Knoxville
I would like to see tips and tricks for duplicating compound bends and mirror image pieces. By duplicating I am interested in many many pieces. What do people do to stream line the production of a certain chassis.
03-29-2008, 12:18 PM | #6 |
Rock Crawler Join Date: Dec 2006 Location: Sierra Vista
I think I could use help on the actual process, I'm sure alot of others could to....such as what part of the flame do you use to heat the joint? I always seem to burn the flux or get the brakeline to hot and it turns black. Maybe just go into as much detail on how you do it in order to help people understand what they should be doing. I picked up a torch some braze and flux and just went at it. I've been trying for a long time now and my brazing still looks like crap in my opinion. Don't get me wrong, my stuff will hold up(my first tuber is still going strong, haven't broken one brazed joint) but I'd just like it to look better than it does. I could sit for hours cleaning up the joints but I know there's a better way to make them look smooth. It seems like some days I start brazing and the joints look like butter, other days they look like boogers...and I do pay attention to what I'm doing and can't figure out the differences. |
03-29-2008, 04:16 PM | #7 |
id be very interested in watching some how-to's. I just started working with brazing and must say ..... you guys are good. ive got 2 frames half built that probably need a dremel to make them usable and one thats ready for a crawler. ( atleast i think and hope so ) id be interested in seeing how hot you guys get the tubes .... like mentioned before what part of the flame to use ..... how you manage to keep the frame so clean from all the burns and flux .... and do most of you paint or powder coat them. |
03-29-2008, 04:52 PM | #8 |
Rock Stacker Join Date: Jul 2007 Location: Wyoming
I need to order some Harris saftey silv 56 because I can't find it around here. My questions is: How many troy onces do you guys use for a tuber build? I would like to get everything I will need in one shot to save on shipping. This will be my first try at brazing. Thanks! |
03-30-2008, 01:02 AM | #9 |
RCC Addict Join Date: Aug 2006 Location: ****, SL,UT
i would like to see how to make and braze on mounts even |
03-30-2008, 01:10 AM | #10 |
let me see if I can do my best here. Deep breath... and talk as fast as I can...LOL i'm in a bit of a time crunch. TJB-Tried flux coated rod and hated it with an absolute passion. Phish-Usually(not always) I'll have a print out of what I'm bending tape 2 pieces togeather and get it done that way. Since I usually do custom stuff that will work for me. But there are companies out there with a 5 axis CNC machine that bends solid rod to whatever you'd like it to be. I've inquired about having the Spyder j done this way and the costs are way outta my leage.. Alot of people will make a Jig that will create the same bends each time. I've never had the time or patients to make anything that would work for me. But I've seen others post some here. I'd search but am limited on time at the moment. Joemama-I've purchased some better lighting for taking videos in my shop and I'm also thinking about possibly having a film student take some video with a high res camera (but doubt it) during the process. Also are you using oxy when you're brazing. Really the only time I get any carbon smoke is when I use oxy.. other than that I don't have the black smoke. my brazing video shows the actual process. just not clearly. Hopefully you'll get something good out of the newer ones. Trigr-I will try to the upper 3/4's of my flame sometimes I'll heat it up and then back off. If I get a joint that buggers up I'll heat it up and try to get it to flow out better while moving the piece around if possible or just turning it over so the buggered end will flow the opposite way. But buggers are something that will happen to everyone no matter how good you are.. I don't think any vendors will argue with me on it. C.O.- For someone just learning and want to make one I suggest getting no less than 2 t.o. .. You should be able to complete a tuber easily with one. but the first one never stays with you and you'll make another plus you may mess up or just change directions and start another. or also just play around to get the hang of it. I finished my first one with at least half left. but messed around with the other half. LOL Thanks for the suggestions. I'll see if I can put something to geather to help as soon as I can. jj Long breath. |
03-30-2008, 01:13 AM | #11 | |
Like shock/link mounts? That will be covered in my start to finish How to. I'll show how I cut and bend every piece as well as cut and drill out the shock and link mounts. | |
03-30-2008, 07:23 AM | #12 |
Pebble Pounder Join Date: Apr 2007 Location: Woudenberg NL
Curious to the how to. As I'm only into soldering at the moment, and want to learn brazing badly.
03-30-2008, 10:38 AM | #13 |
I wanna be Dave Join Date: May 2006 Location: akron
aluminum how to would be sweet.
03-30-2008, 11:55 AM | #14 | |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
I could do this one. everything is pretty much the same as steel brazing except: - use ALCOR braze rod from Harris (check thier website for avail.) NOTHING ELSE WORKS AS GOOD IF AT ALL (read that part again if you are confused) - No flux (rod is flux cored) - Super clean bonding surface (clean with stainless steel brush) - Less heat, more braze. I will chime in on this thread when I can, help JJ out (he has a lot to learn) p!nK | |
03-30-2008, 12:44 PM | #15 | |
and thanks pink | |
03-30-2008, 02:42 PM | #16 | |
p!nK | |
03-30-2008, 03:31 PM | #17 |
I am gonna try it this week TY |
03-30-2008, 05:04 PM | #18 |
| One more newbie question, sorry I’m not trying to hijack your thread. As I mentioned before, I can’t find Harris products here locally, so I am trying to find a good place to order it online. I did see in the other brazing thread that I should look on froogle.google.com for it, and I found some. But I don’t want to just give my credit card out to some random online company. Is there a good place you guys use and would recommend, or even better is there a vendor on here that sells it? Thanks so much for all the help! |
03-30-2008, 05:30 PM | #19 | |
p!nK | |
03-30-2008, 08:37 PM | #20 | |
This is where I got mine from. Dont know how the $$ is compared to other sites but it was my easiest find when I was looking. Their shipping was quick to and reasonable. http://buildinghvac.com/acatalog/Pro...68.html#a75310 | |
