| | #1 |
| Rock Stacker Join Date: Jul 2005 Location: connecticut
| ok i wanna take a whack at building my own tuber. and i want to know 1.) what is a good cheap torch (like a butane mini torch) to braze with, 2.)what is a good tool to cut brake line with? and 3.)whats a good bender for the brakeline, or should i just make a jig and bend it by hand? thanks chris Last edited by xmaxxboyx; 08-08-2005 at 02:48 AM. |
| Sponsored Links | |
| | #2 |
| 2006 2.2 National Champ ![]() Join Date: Dec 2004 Location: Driving my R/C rototiller
| This will get you pointed in the right direction. http://rccrawler.com/tuber.htm |
| | #3 | |
| Quarry Creeper Join Date: Jan 2005 Location: New Orleans
| | #4 |
| Pebble Pounder Join Date: Oct 2004 Location: Colorado
| I “think” Jay uses either the Prestolite or something similar. I think his site used to show a picture of his torch. I use a Victor medium duty right now. It’s a little large for Brake Tubing though. I think this one is more suited for the RC Hobby: Meco Midget Torch $ 115 Torch + Victor Regulators $255 Source: http://www.tinmantech.com/html/meco_midget_torch.html FAQ from the “Tinman” http://www.tinmantech.com/html/faqs.html |
| | #5 |
| | #6 |
| Quarry Creeper Join Date: Jul 2004 Location: In the shop terrorising the cat with the heli.
| Lowes has an oxy map gas rig for around $50 I think. It will take about 4 bottles of oxygen to build a tuber. http://www.lowes.com/lowes/lkn?actio...550&lpage=none |
| | #7 |
| I am getting one of these: http://tsijeweltools.com/merchant.ihtml?id=139&step=2 Thanks for the help guys! -Will |
| | #8 |
| Rock Crawler Join Date: Sep 2004 Location: a place of settlement, activity, or residence.
| Not to sound like a jerk, but I would steer clear of those kits that use the map gas and disposable oxygen tanks, the cost of oxygen tanks over time would far exceed the cost of a decent refillable portable torch set. You will go through about 15 bottles of oxygen before you run out of map gas. At roughly 7 dollars a pop (depending on location, around Omaha they run $ If you don't plan on building more than a couple of chassis, the small rig will do just fine, but if you plan on doing more than that I would definitely check out the refillable option. It will allow you greater capabilities and it will look great on your bench as well! |
| | #9 |
| hows this http://www.blazerproducts.com/tools/bigshot.html that doesnt show a price, so can someone please recomend a torch for about $30 Last edited by xmaxxboyx; 08-10-2005 at 01:40 AM. |
| | #10 |
| You pretty much need oxy and mapgas or acet for brazing with hi temp silver solder. You can do it with low temp and map gas but its not going to hold very well. One good rollover and your probably going to crack half your joints with low temp. As far as cutting brake line a dremel with a cutting disc works fine. As far as bending it I use a piece of 3/4 oak plywood with three 3/8 wooden dowls int it. Two on the same line placed about 1 inch apart and the third about 1/4 inch below one of the top ones basically an L shape. This works good for me and you usually get a good bends (not flattening out the tube) Hope this helps. |
| | #11 |
| Newbie Join Date: Aug 2005 Location: over yonder
| | #12 |
| Pebble Pounder Join Date: Jun 2005 Location: Millerton, PA
| a propane torch burns even cooler yet than a mapgas torch alone. Definitely find some sort of oxy/acetaline setup. |
| | #13 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| take off your propane bottle and screw on a mapp bottle, since propane doesn't get hot enough...use a grinder w/ cutoff wheel or dremel to cut brakeline or even a hacksaw if needed... make a jig for smaller radius bends and get a decent brakeline bender w/ degree marks on it. then make sure you get the Harris safety silv and the white flux to go with the safety silv.don't use plumbing solder.. then get busy.. it's that simple... You can buy one of those kits that use oxygen and mapp. i use one also sometimes. it gets the job done faster than just mapp, but just mapp alone will work.with the mapp/oxy kit, you will go through 2 bottles of oxygen to 1 bottle of mapp and the oxygen bottles are $8 a bottle. I also have a set of portable torches and they are just too big for this type of work. |
| | #14 |
| Rock Stacker Join Date: Aug 2005 Location: Between 2 Rocks
| I was wondering if you could use a mig welder??? |
| | #15 |
| whatever! ![]() Join Date: Jun 2005 Location: The bunker
| i've got a miller 210. i tried it with.030 wire. it was too thin for me. you may be a better welder though. |
| | #16 |
| the only time i use a welder ( which is a 110, not a 220 ) is when doing solid rod or just tacking some brakeline in place so i can braze it. that way i don't need all kinds of crap to hold it in place while i braze. anytime i try to weld brakeline, i just burn through it.. but once you get brazing down pat, it is alot easier and cleaner than welding |
| | #17 |
| Quarry Creeper Join Date: Jun 2005 Location: Apache Junction
| i bought a micro jewlers torch $110 @ the gauges were $50 bucks each at weldingdepot.com ,oxy-ace bottles$120 |
| | #18 |
| Newbie Join Date: Oct 2005 Location: Taylor Mill,KY
| why not tig it or get someone to do it for you yall live out west around oil fields welders should be all over the place you can tig anything if you know what your doing if you cut & bend everything they shouldnt be much of a charge to do it just a thought |
| | #19 |
| Dirt Addict ![]() Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
| One problem with MIG welding is getting the welding nozzle in tight places. TIG could work well but getting the nozzle and the rod into tight places would make it pretty difficult. One advantage to brazing is you can kinda get the braze rod to flow "around" the joint without having the torch at every angle on it. Can't do this as much with an arc weld process. Jay Last edited by roktoy; 10-25-2005 at 09:01 AM. |
| | #20 |
| Rock Crawler Join Date: Apr 2004 Location: Longmont, CO
| I have one of those $360 cutting/welding oxy acy outfits like they sell at Home Depot. Works pretty good but the torch is a little big and akward for a tuber. So I picked up one of the littletorches like posted above. The thing works great, I'm VERY happy with it. I just attached it to my bottles from the Home Depot rig. I got mine at A2ZMetalsmiths in Denver... Great place to buy stuff like this in Colorado. They mail order too. www.A2Zmetalsmith.com They sell two kits propane/oxy and act/oxy. Mine has the bigger tips, prop/oxy I think. The smallest tip is about unusable (for r/c) so I'm glad I got the bigger tips. |
| Thread Tools | |
| Display Modes | |
