12-12-2009, 10:44 PM | #1 |
Quarry Creeper Join Date: Oct 2009 Location: Indianapolis, IN
| What size drill bit for hole to be threaded M3?
I've broken two taps in the last five days. They were part of a cheap $10 kit from Harbor Freight and were a drill bit/tap combo. I'm not buying another kit and just saw that I can get an M3-.50 tap from Snap On for $5.35 plus shipping. What size drill bit do I need to use to follow up with this tap?
12-12-2009, 10:48 PM | #2 |
Rock Crawler Join Date: Feb 2009 Location: Chandler, AZ
I use a #39 but a #40 works too.
12-12-2009, 10:53 PM | #3 |
Thank you
12-13-2009, 12:00 AM | #4 |
Rock Crawler Join Date: Feb 2009 Location: On the "ROCKS"
I use the Harbor Fright ones all of the time, and I've never broke one. Make sure you are using oil on the Tap and taking an air hose to it, before and after each turn of the tap. Last edited by SaxtonSlaughter; 12-13-2009 at 12:04 AM. |
12-13-2009, 12:11 AM | #5 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
a big thing too is dont try to cut all of the thread in a sngle turn,,turn the tap in a bit then back out a tad then back in,,let it actually cut the threads then clean them as you run the tap in...the shavings are usually what cause a tap to bust as they build up on the lead cutting edge of the tap..backing it out just a little bit after a bit of turning it in will break the shavings off the leading edge and allow the tap to work better and easier..ive been running the same same set of misc. taps for about 5 maybe 6 years
12-13-2009, 06:32 AM | #6 |
Rock Stacker Join Date: May 2005 Location: West Bend
A 2.5mm drill would be ideal. The best way to figure metric sizes is to take the tap size (3mm) minus the pitch (.5) to achieve the correct drill size.
12-13-2009, 09:59 AM | #7 |
Quarry Creeper Join Date: Jul 2008 Location: Ventura, Ca
wikipedia has a good sizing chart for drill size compared to tap size. If you click on the chart you get a full machinists charts of every size possible http://en.wikipedia.org/wiki/Tap_and_die Last edited by sbarnesvta; 12-13-2009 at 09:59 AM. Reason: forgot link |
12-13-2009, 10:56 AM | #8 |
Rock Stacker Join Date: Dec 2009 Location: Clemson
Get some proper cutting fluid. That stuff is way cheaper than constantly breaking taps and drill bits in steel. You will want to take care of the snap-on tap, clean it out after use and don't ever force it. A tap that small has very little resistance against twisting, so back it out anytime it stops. And if you have a choice between two bits that aren't exactly labeled on the tap, consider your material. Steel will work fine with a drill bit slightly larger than labeled, a material like brass or aluminum will do better with a slightly smaller bit. Good if your drill set doesn't include all of the numbered sizes (mine goes by 1/64in increments). |
12-13-2009, 11:06 AM | #9 |
Thanks for all of the help. I'd admittedly a complete newb to metal work and I'm learning as I go. This type of information is very helpful.
12-13-2009, 11:33 AM | #10 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
2.5 mm or #39 or 40 sometimes depends on what you are tappimg... |
12-14-2009, 04:35 PM | #11 | |
Quarry Creeper Join Date: Mar 2008 Location: i think its called houston
| Quote: as far as the taps go, i too have the harbor freight ones and i have only broken the 4-40 one. Be easy and gentle and add lube kinda like the first time...haha | |
01-07-2010, 03:45 AM | #12 |
Rock Stacker Join Date: Jan 2010 Location: spokane
01-07-2010, 11:44 PM | #13 |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
1 turn in 1/2 turn out if shes tight and flaky a little lube/liquid courage always makes nice and smooth |
01-08-2010, 12:20 AM | #14 | |
Cutting taps do exactly that,they actually cut the threads. Forming taps,they roll the chips and form the threads. Depending on material and the application,they both have their place. Believe it or not,the threads from a form tap are allot stronger than you would imagine. Good cutting oil and the proper sized hole is key. Hand tapping sucks...to dang slow. At work,naturally I use my machine and power feed everything. At home,when fooling with these little taps,I use my cordless drill and power feed the tap with it. Much faster and easier. | |
01-08-2010, 12:37 AM | #15 | |
I joined the Band! Join Date: Jun 2008 Location: Sacramento
so a m3x.5 cut tap is 3-.5=2.5 convert to english is 2.5/25.4 = .098 or #40 i know im way to late but, i think it still good info... | |
01-08-2010, 12:41 AM | #16 |
| very close on your description, roll taps actually do not form a chip at all, they cold form the thread, and yes cold form threads are stronger than cut threads.
01-08-2010, 12:45 AM | #17 |
01-08-2010, 12:48 AM | #18 |
01-08-2010, 12:49 AM | #19 |
