05-13-2010, 10:27 PM | #1 |
Rock Stacker Join Date: Jan 2006 Location: aberdeen
| brazing chassis question
ok i kno u guys have heard this a lot but im wanting to get into brazing but could u guys make me a list on all i need to buy i kno to use break line but what do i use for the braze a list of stuff for a newbie would be helpful thanks guys ur a lot of help!!!!!!! i wanna start makin a chassis |
05-14-2010, 01:50 AM | #2 |
Pebble Pounder Join Date: Jun 2006 Location: Sacramento, near Antelope
1. Safety Silv 56 (this is the silver solder) 2. Safety Flux 3. Break tubing (not painted/coated) If there's coating, you gotta remove it. 4. Mapp torch (propane just aint hot enough to do it right) 5. Flint striker (to light the torch) 6. Safety glasses (get the ones that are designed for welding or brazing) 7. Dust mask (minimum) You never know what the fumes will do you your health. I've made a few chassis using the Safety Silv 56 and none of them have broken, even after several long falls. |
05-14-2010, 06:58 AM | #3 |
06-16-2010, 07:18 AM | #4 |
Rock Crawler Join Date: Dec 2008 Location: Fortuna Calif.
That is a great read, on brazing, how did I miss it? It cleared up a few problems I have encountered brazing tubing. Thanks
11-11-2010, 01:27 PM | #5 | |
Quarry Creeper Join Date: Mar 2009 Location: Raleigh
| Quote: | |
11-11-2010, 03:04 PM | #6 |
RCC Addict Join Date: Nov 2009 Location: Tulsa
What about when u braze not silver solder. What kind of brazing rod should u use And diameter
11-11-2010, 08:47 PM | #7 | |
Try this: http://www.rccrawler.com/tuber.htm | |
11-12-2010, 05:49 AM | #8 | |
Rock Stacker Join Date: Dec 2009 Location: Clemson
Silver "solder" is technically brazing, the rod melts at higher than 800*F (actually around 1200*F). The difference is far better flow and wetting with the silver (strength is the same when done properly). | |
