03-18-2006, 02:39 PM | #1 |
Pebble Pounder Join Date: Dec 2005 Location: Fenton
| Tig Welded Aluminun Cage ???
Im getting ready to start my fusion Rock buggy Project.. going to be using 3/16's SOLID rod.. Steel seems like it would be a heavy finished project.. So im thinking about using Aluminum rod (plus aluminum was cheaper when i looked for prices) i have a guy who could TIG weld the whole thing together for me.. My question is how strong will it be ?? should i stick with steel and braze it together? or would a tig welded frame be just as strong or stronger ?? and if i do go TIG'd Aluminum can i just tack it together with a MIG to hold it til he welds it complete ? I'm aiming for a finished project like this Project: Fusion-X |
03-18-2006, 02:41 PM | #2 |
Rock Crawler Join Date: May 2005 Location: In front of my comp
You cant tack weld aluminum with a mig. At least i dont think you can. A mig is made for welding steel and other metals liek that. Not aluminum.
03-18-2006, 02:46 PM | #3 | |
and if you set it up right u can weld aluminum with a MIG | |
03-18-2006, 02:48 PM | #4 |
Oh ok. Then whyd you ask? I never knew u can weld aluminum with a mig.
03-18-2006, 02:48 PM | #5 |
Newbie Join Date: Jan 2006 Location: Ocean county
there is no reason you couldnt use a mig to tack it together provided it is set up properly. it may not be the best process but yes it is doable. a 120 mig setup with the proper gas, polarity spool gun and practice would be just fine for AL. welders are not made for specific alloys. rather they get set up according to what you are welding at what size. |
03-18-2006, 10:30 PM | #6 | |
03-18-2006, 10:40 PM | #7 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
What do you see as the advantage of solid 3/16" alum rod over, say, 3/16" steel tube? 3/16" brake line is cheap and easy to braze.....................why go to tig'ing aluminum? |
03-18-2006, 10:47 PM | #8 | |
Seriously.. i wana go with solid for strength.. I work in the automotive field so i use brake line VERY often.. I just dont see the strength i want in that stuff.. Seems solid rod will hold up to my abuse better | |
03-18-2006, 11:09 PM | #9 |
Newbie Join Date: Dec 2005 Location: OZ
I made a cage up out of disguarded shopping trolley,(pic 1) stainless, it weighed a S#*T load, but it was really strong. Then found the world of brake line, I braised one and bolted on some alloy plates, see pic 2. This thing has taken an absolute beating and is still holding. If its strenght you are after it all comes down to how you brace it. IMO. Anyway go nuts, if you do it don't forget pics. pic 1 http://www.rcpics.net/view_single.php?medid=75059 pic 2 http://www.rcpics.net/view_single.php?medid=75060 |
03-18-2006, 11:13 PM | #10 |
Do you work with 3/16" aluminum rod much? You can build your rig as you want to, but between 3/16 brakeline and 3/16 aluminum rod, I will take the brakeline any day (just for the brazing simplicity). With that said, with my own home tube/rod bending tests................the rod may be a little stronger than the brakeline given a good amount of length, so when length is required, rod will definately be stronger in regards to long. forces placed upon it. IE, for susp links I would choose rod over tube any and every day. BUT, since tube/rod used in building frames, the total lengths in individual pieces is usually so short, that long. forces against the material become almost non-existant. Most brakeline tuber chassis built can easily withstand the builder standing on them without screwing them up, which is more than a test than they will see on the rocks. |
03-19-2006, 01:48 AM | #11 |
Hmmm... i guess ill go check the price on brake line tomarow... i just install it.. i never have to worry about prices lol
03-19-2006, 07:41 AM | #12 |
Pebble Pounder Join Date: Aug 2005 Location: Rochester
If you really wanna go beefy, you can always use 4130 tubing from McMaster...
03-19-2006, 08:44 AM | #13 | |
Quarry Creeper Join Date: Jan 2006 Location: Ukiah, CA. (nor cal)
I was actualy amased at how strong everything is once safty-silv'ed together.... FWIW unless this person has experience tig welding SMALL aluminum parts you may end up with a big mess....I've done my share of tiging alum and there is no way I'd attempt doing a aluminum tuber sounds like a PITA , but then again I don't have much experience with small parts.... | |
03-19-2006, 07:55 PM | #14 | |
I was planning on using Flux coated coper Brazing rod if i went the steel way, I can not find that saftey silver stuff for the life of me ANYWHERE ! | |
03-19-2006, 08:58 PM | #15 | |
Quarry Creeper Join Date: Nov 2004 Location: MANVILLE
03-19-2006, 09:00 PM | #16 |
dude the safty silv is much nicer I've used both and the brazing rod sucks compared to the safty silv..... ramweldingsupply.com has it online.....
03-19-2006, 09:04 PM | #17 | |
03-19-2006, 10:33 PM | #18 | |
what flux do u use with that stuff ?? and do u use a Mapp gas torch ? | |
03-19-2006, 10:57 PM | #19 |
here you go https://secure.ramweldingsupply.com/...ew.mcic?s=1423 and the flux https://secure.ramweldingsupply.com/...ew.mcic?s=1544 yea just mapp works fine.... |
03-19-2006, 11:45 PM | #20 | |
Thank you sooo much Damn the shipping on that stuff will kill you.. does Homedepot carry this stuff ?? i couldnt find it at lowes... Id rather save the 10 bux and just go to the store.. | |
