01-27-2014, 10:41 AM | #1 |
Pebble Pounder Join Date: Sep 2012 Location: San Francisco Bay Area
| Where to get steel tube for brazing?
I've checked with Napa, O'Reilly and a local steel shop.. Anywhere to get them online other than McCaster?
01-27-2014, 11:06 AM | #2 |
Rock Crawler Join Date: Oct 2012 Location: Garden Grove
| Re: Where to get steel tube for brazing?
I was lucky and found a loop at Oreilly's that they had left. You might try a GoodYear or an auto shop that does brake work. But the best bet would be McMaster. |
01-27-2014, 12:22 PM | #3 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
napa has always had the uncoated brake line 3/16" to 3/8" dia in 60" lengths ....
01-27-2014, 12:24 PM | #4 |
Rock Stacker Join Date: Jan 2008 Location: Victoria BC
I've been chucking lengths of Poly armour in the drill and using 120 grit to clean them off. I do the same with the plain steel though too to get the galvanized coating off.
01-27-2014, 12:52 PM | #5 |
Pebble Pounder Join Date: Feb 2011 Location: Cookeville
| Re: Where to get steel tube for brazing? |
01-27-2014, 02:23 PM | #6 |
RCC Addict Join Date: Jan 2007 Location: caldwell,idaho
you can try o'reiley online for the 25 foot rolls.
01-27-2014, 02:28 PM | #7 |
My local Napa and O'Reilly only had the coated ones. I want non rolled pieces. Unrolling it is gonna be a pain... There was a website for tube but I can't remember what it was.. |
01-27-2014, 05:33 PM | #8 | |
| Re: Where to get steel tube for brazing? Quote:
well dang, looks like I'm going on a buying spree at napa .... | |
01-27-2014, 06:03 PM | #9 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
i keep seeing a lot more reference to hydraulic line/tubing instead of brake line since the auto parts stores are carrying less of the uncoated stuff these days. my guess is a supplier like mcmaster/grainger or similar is the easiest source for the stuff.
01-28-2014, 06:36 AM | #10 |
Here are some part numbers for a 60" piece of tubing. BK 813-1266 - 3/16" x 60" BK 813-1225 - 1/4" x 60" Warehouses around the US show plenty of each of those part numbers. If y'all need any other, just holler at me. |
01-28-2014, 10:18 AM | #11 |
01-28-2014, 11:10 AM | #12 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
MSC direct has all the tubing you will ever need. Stainless, DOM, various wall thickness and diameters. Shipping is really fast.....
01-28-2014, 12:00 PM | #13 |
01-28-2014, 01:56 PM | #14 |
| Re: Where to get steel tube for brazing? I have two local napa's within 20 miles of me and most likely on my route at least once a week near one or the other....i'll just stop in and buy up what they have, then they will need to stock up and get what ever un coated is left shipped to them so I can buy it all again ....
01-31-2014, 06:33 AM | #15 |
RCC Addict Join Date: Jun 2013 Location: Port Saint Lucie, Florida
just came across this on ebay Tubing Welded ID 148" OD 3 16" 6 ft L Wall 020" 304 Stainless Steel | eBay |
01-31-2014, 08:51 PM | #16 |
Newbie Join Date: May 2010 Location: Utah
I get mine at napa
02-01-2014, 01:58 AM | #17 | |
02-01-2014, 07:19 AM | #18 |
| Re: Where to get steel tube for brazing? not sure if this is all stores or just the one you were in, but I went to one of my local napa stores to stock up with 4 60" pcs and asked them....the guy had no info on any brake line being discontinued, I even called my other napa and got the same answer....
02-01-2014, 12:22 PM | #19 |
RCC Addict Join Date: Jun 2008 Location: In the woods
Advanced auto and autozone sale it as well.if it is coated,I use dremel and sanding drum to remove it.have been doing this for a while now.It is $8-$9 for 5'x3/16 and $7.53 for 6'x1/4"
02-01-2014, 01:26 PM | #20 |
RCC Addict Join Date: May 2011 Location: at home
| Re: Where to get steel tube for brazing? Order Alloy Steel 4130 Tube in Small Quantities at OnlineMetals.com for alloy tube Order Mild Steel A513 Tube in Small Quantities at OnlineMetals.com for type 5 steel tube both come in .25 |
Where to get steel tube for brazing? - Similar Threads | ||||
Brazing/welding and tube bending o my | JeepCrawler | Newbie General | 4 | 11-24-2007 04:52 PM |
Brazing Stainless steel? | TheNewbie | Newbie General | 2 | 11-20-2006 05:54 PM |
steel brake line brazing | C-crum | Tools, and Procedures | 2 | 09-14-2006 01:20 PM |
How far can steel tube bend? | ILoveRCRockCrawlin | Tools, and Procedures | 21 | 02-12-2006 02:16 AM |
tube wall thickness, what brazing rod to use and how much | Skippy | Tools, and Procedures | 3 | 12-20-2005 07:51 PM |
