01-21-2012, 01:09 PM | #21 |
Quarry Creeper Join Date: Feb 2007 Location: Pontoon Beach
| Re: At Home Powder Coating
I have had a eastwood kit for about 12yrs the only thing I ever had problems with was the 2 stage chrome I used a normal house stove out in my shop, a few guys here at work have made their own for doing chopper frames. They basically just welded two ovens side by side and would slide the chopper in on a big rack. I would STRONGLY suggest getting a make shift paint booth with a filter and fan to catch all that dust. If you let it sit on something too long it is almost impossible to get off of it..I have to repaint my 81 prostreet cutlass because of it.. |
07-24-2012, 04:46 PM | #22 |
Rock Stacker Join Date: Apr 2010 Location: De Soto, Ks
I realize a spammer brought this to the top, however after reading it I must say... DO NOT EVER POWDERCOAT IN AN OVEN YOU EAT FOOD OUT OF!!!!!11!!!11 YOU WILL DIE! seriously though dont do it, its not safe. You can buy a used over for less than $100 and not be eating toxic paint dust with your dinner I've used both the Sears and HF powderguns for years and they do a decent job. |
07-26-2012, 02:21 PM | #23 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
first off your part needs to be properly cleaned with a iron phosphate chemical to draw out any oils in the metal then properly ground then coated if its not cleaned properly it will not be as durable...i use a Gema OptiFlex2 gun box feed.
07-26-2012, 07:34 PM | #24 | |
Rock Crawler Join Date: Oct 2011 Location: south of nowhere
| Re: At Home Powder Coating Quote:
Iron phosphate is a conversion coating used as a final etch and rust preventative, helps the powder to adhere better to properly cleaned parts, it by itself is not a degreasing agent. You can buy cleaner/degreasers mixed with a phospatizing agent, although in my experiance they don't work as will as separate 2 stage system. Gema guns are by far the best on the market, but the $6,000 price tag for an Optiflex2 box feed unit, makes it a little steep for a home unit. Prep work is key in all coating applications for sure. | |
07-26-2012, 09:09 PM | #25 | |
07-27-2012, 09:29 AM | #26 | |
I am familiar with Powder X's cleaner. I've been using Gema for 20 years, and have demoed most other major brands over the years, and owned some too, nothing comes close to Gema. Always buy good quality powders, from the major manufacture's stay clear of eastwood all together. | |
At Home Powder Coating - Similar Threads | ||||
Powder Coating? | Agama | Colorado | 6 | 06-13-2011 12:26 PM |
Powder Coating at Home , (have you done it?) | 4x4Crawler4LIFE | Paint and Body | 1 | 03-22-2008 07:44 PM |
Powder Coating. | Mule | Tools, and Procedures | 16 | 12-17-2006 12:14 AM |
