05-13-2012, 03:39 PM | #1 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
| crawler course
i'm trying to build a simple course for my rock crawler. but i dont know if regular topsoil would be good to use instead of dirt. has anyone used topsoil for their courses?
05-13-2012, 04:42 PM | #2 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
| Re: crawler course
top soil and dirt are the same, if your talking potting soil then that's not dirt but organic stuff broken down into what that is........bob .... |
05-13-2012, 04:49 PM | #3 |
| Re: crawler course |
05-13-2012, 05:21 PM | #4 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
| Re: crawler course
id just use dirt or red clay
05-13-2012, 08:18 PM | #5 |
Newbie Join Date: Apr 2012 Location: Southern Maine
| Re: crawler course
Do you mean topsoil, or sand? As it was already pointed out dirt/topsoil is pretty much the same. I would use sand, or a mixture.. I think topsoil would be too sticky and remove some of the challenge on or around rocks, sand would add a little slippage which is more of a challenge, but I'm also new at this. |
05-14-2012, 05:43 AM | #6 |
Rock Crawler Join Date: Oct 2011 Location: Warren
| Re: crawler course
Cant go wrong with a stack of rocks.
05-15-2012, 06:05 AM | #7 |
| Re: crawler course
Dirt is dirt.....who knows what is in it. Topsoil is usually screened, that takes out the rocks/small stones, roots, twigs, etc. Potting soil is usually a mix of topsoil & mulch. Dirt is the cheapest/easiet to use, I would use it. Actually, I would use rocks, unless you're asking how to hold the rocks and are going to use the dirt to "lock the rocks in place". |
05-27-2012, 02:55 PM | #8 |
Newbie Join Date: May 2012 Location: brattleboro
| Re: crawler course
top soil will turn to shi% after rain, i'd use gravel with some sand or use pea stone...
06-04-2012, 04:48 PM | #9 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
| Re: crawler course
Whatever is under your grass is probably the right thing to use for trailing once it's packed down. Add some rocks and lumber and you'll have some crawling. Potting soil is generally not dense enough to compress well for trails. It's usually got a filler in it to allow for drainage.
crawler course - Similar Threads | ||||
Difference in AX10, Night Crawler, and Comp Crawler final gear ratios? | shelljeep | Newbie General | 11 | 02-05-2010 12:48 AM |
TCS - Novak Goat Crawler Systems in stock @ TCScrawlers.com - The Crawler Store | kevinlongisland | Vendors Market | 0 | 09-14-2007 09:34 AM |
TXT Crawler.... Stone Cold Crawler... Full Tube Scale build | RockSpyder | Tamiya Txt-1 and Juggernaut | 6 | 12-14-2004 09:40 AM |
