07-21-2012, 05:43 PM | #1 |
Quarry Creeper Join Date: Jan 2009 Location: B-E-A-utiful Vancouver Island
| Best method for holding small pieces of tube while fish mouthing??
Im having a hell of a time trying to hold small (1/2" to 1/4") pieces of 3/16" tubing so i can file the fish mouth both ends for braceing in my southern buggy im working on. I have tryed using a vice, vicegrips, hell ive even tried just holding it. Everytime it either slips or it crushes the tube Some pieces r taking upwards of half hour and several atemps to get right There has to be a better way!! Any help is welcome Last edited by Rockridge; 07-23-2012 at 03:34 PM. |
07-21-2012, 05:54 PM | #2 |
| Re: Best method for holding small pieces of tube while fish mouthing??
I always use my bench vise. I just clamp as much of the end of the tube as possible so it doesn't move when I'm filing the fish mouth.
07-21-2012, 05:54 PM | #3 |
Rock Crawler Join Date: Mar 2011 Location: hampton
mount your file in the vice and rub the tube on the file with your hand
07-21-2012, 06:41 PM | #4 |
| Re: Best method for holding small pieces of tube while fish mouthing?? |
07-21-2012, 06:47 PM | #5 |
I konw they make a tube vice for bigger tube (like 2")..... do they make somthing similar for 3/16" tube?
07-21-2012, 06:49 PM | #6 |
Newbie Join Date: Nov 2011 Location: San Diego
If you have a drill press and round file or stone you put the file in the chuck and as it spins hold the tubing up to it
07-21-2012, 06:49 PM | #7 |
Quarry Creeper Join Date: Oct 2008 Location: Oakley
Couple of suggestions you might try... Cut the fish mouth on one end of the tubing before cutting to length, this would leave you with 1 end to do to a short piece. Take a piece of wood, plastic, aluminum, pretty much anything you have around and drill a hole same size as the O.D. of the tubing to a depth that will leave the end sticking out enough to fish mouth. The hole will support the tubing while you file away.. |
07-21-2012, 06:57 PM | #8 |
these r all excellent methods that will definetly be trying out. thanks for all the replies |
07-21-2012, 08:18 PM | #9 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i use my bench grinder on the corner of the stone for fish mouthing tube....just a quick second or two to get a groove started and finish up with my 3/16" chainsaw file, bout 4 minutes and done........bob .... |
07-21-2012, 11:06 PM | #10 |
Quarry Creeper Join Date: Mar 2009 Location: Grande Prairie, AB, Canada
Does any use a dremel to fish mouth there tubing? Sent from my GT-I9100M using Tapatalk 2 |
07-21-2012, 11:28 PM | #11 |
Use a pin vise that has a chuck on it! Perfect for holding onto small round stuff and really handy for cleaning up holes with drills and stuff like that. |
07-22-2012, 09:33 AM | #12 |
07-22-2012, 11:48 AM | #13 |
07-22-2012, 03:25 PM | #14 |
07-22-2012, 05:23 PM | #15 |
so with it being sunday not much is open which left me with only one option, search around the garage and see what i could come up with.... Well after some serious brain storming this is what i came up with....(still gonna see if i can find a pin vise this week, but for now) I found a drill Chuck that clips into my 1/4 drive cordless impact driver ( u know the one that fits screw driver bits) put it in the vise and vola. I also found that useing a pice of solid stock that fit inside the tube worked well for when i needed to fine tune my fishmouth. clamp it in the vise and slide the tube over it... |
07-22-2012, 05:47 PM | #16 | |
| Re: Best method for holding small pieces of tube while fish mouthing?? Quote:
07-22-2012, 05:54 PM | #17 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
07-22-2012, 08:30 PM | #18 |
ya the bench grinder sounds like a great way to start the cope, unfrotunatly as of now i do not have a bench grinder to test it out its on the list of "to get items"
07-22-2012, 09:27 PM | #19 |
I just took some pictures for another thread I was about to start, but this is a great place for some of them. First off, I don't consider 1/4" to 1/2" small. At least not for what most of us do. 3/16" is usually the norm, so that's what I'll show pictures of. One of my favorite bench tools is my Palmgren Machine Vise. I got this from toybuilder, and use it all the time. For this application I really like the grooved stationary jaw. It allows me to clamp round stock one of two ways: When holding small pieces, I clamp it in the vise and then hold it with my thumb and middle finger: This acts as a guide for the file. Then just file until you get the desired depth |
07-22-2012, 09:40 PM | #20 | |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
Food for thought, my Dremel was around 50.00, but my bench grinder was 30.00 and angle grinder was only 20.00, both from Harbor Freight. The bench grinder I have had for 2 years now with no issues. | |
Best method for holding small pieces of tube while fish mouthing?? - Similar Threads | ||||
source for small steel square tube? | R/CMaxximus5.0 | Tools, and Procedures | 12 | 02-19-2013 09:54 AM |
Holding pieces while brazing | 66sprint6 | Tools, and Procedures | 20 | 04-09-2011 08:59 AM |
Cleaning The Steel and Fish-Mouthing Without a Dremmel?(and other details) | TheHeadHunter | Tools, and Procedures | 10 | 07-22-2008 08:34 PM |
Fish Scale G2 - Tubewerks Tube Frame | Fishmaxx | Tamiya TLT Crawlers | 12 | 08-25-2005 06:58 PM |
Tube chassis construction, can anyone explain welding method | TwistedXT | Tamiya Txt-1 and Juggernaut | 10 | 09-24-2004 04:08 PM |
