02-23-2013, 08:30 AM | #1 |
Newbie Join Date: Dec 2012 Location: orlando
| Brazing
What's the difference between a propane torch and a MAP torch.Which would be better to use in brazing?
02-23-2013, 08:44 AM | #2 |
Rock Stacker Join Date: Mar 2012 Location: longview
| Re: Brazing
propane with oxygen is ok. propane by itself is not hot enough. map gas is ok by itself. oxygen with acetylene is hottest. my regulators are leaking so I use map gas |
02-23-2013, 10:04 AM | #3 |
| Re: Brazing
Ok.Thanks for your help.
02-23-2013, 10:22 AM | #4 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: Brazing
Mapp burns hotter than propane. Propane will braze small tubing and thin flat stock,it just takes a bit longer to get to temp, 1/8th or smaller solid stock will also braze with propane. Mapp is a better choice for the little difference in price, just make sure you torch head is compatable with mapp gas. I find using bare brass/bronze rod and dipping it into the powdered flux works way better than the precoated flux rods you can buy. 1/16th fllier rod is my choice, it will reach melting temp quicker since the is less of it to heat up. Its all about temp control to make nice joints........ |
02-23-2013, 10:24 AM | #5 |
| Re: Brazing Partially correct, depends on the thickness of the material. I have yet to find a material we use in the fab of the crawlers that I cant braze with propane. |
02-23-2013, 07:53 PM | #6 |
Newbie Join Date: Jul 2010 Location: LRAFB, AR
| Re: Brazing
Do you use the normal size tip likeon a plumbers torch, or do you have something smaller to get a finer flame point
02-24-2013, 10:23 AM | #7 |
| Re: Brazing
With mapp or propane I use the bernzomatic 4000 plumbers torch head. I also use oxy/acet set ups with a small tip or a jewelers torch depending on what I am doing. The 4000 will do it all,but I find the heat control to be more effiecient with the oxy/acet set up in certain situations,especially when using harris safety silv. |
03-01-2013, 11:55 PM | #8 |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
| Re: Brazing
I'm using a jewlers torch that uses oxy/propane and its really good, I haven't had a chance to use mapp gas yet
Brazing - Similar Threads | ||||
Brazing...You can do it if I can! | RyansRubicon.co | Tools, and Procedures | 22 | 03-30-2010 02:22 PM |
Brazing help | jakedizzle | Tools, and Procedures | 4 | 07-04-2009 08:50 PM |
New to Brazing... | Nates Creations | Tools, and Procedures | 5 | 06-18-2009 04:47 AM |
brazing | revoracer99 | Tools, and Procedures | 1 | 03-01-2008 12:12 AM |
brazing help | johnnyt | Newbie General | 4 | 11-28-2006 04:49 AM |
