Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tools, and Procedures
Thread: help
Old 09-11-2006, 06:51 PM   #1
Default help
im trying to build a sandrail out of brake line. i have never built one before and i was woundering the techniqes to put it toghether i have been trying solder but its not very strong and all's i have is a propane tourch but it dosent seem to melt the brazing rod very well please help
motox67 is offline   Reply With Quote
Old 09-11-2006, 08:10 PM   #2
You are going to get flamed for not searching.....
mr.maxx is offline   Reply With Quote
Old 09-11-2006, 08:56 PM   #3
Priceless.......well ill be nice and i wont flame you for not using the search button.....
Soldering brake line will never work, nowhere near strong enough, Propane torch.......ditch it and gain access to an oxy-acetylene setup and do some real brazing. Other than that draw a mock-up design on paper and tape all your joint together so it will hold and take the tape off one piece at a time and braze the joint. Hope that helps.
P.S. Use the search button next time, i can think of 2 threads in the past week that covered this topic.
Canadian Crawler is offline   Reply With Quote
Old 09-11-2006, 09:04 PM   #4
DO NOT ditch your propane torch!!!!
Keep the torch, and go to Lowes or Home Depot and get a bottle or two of MAPP gas (yellow bottles). MAPP offers more than enough heat to braze.
You will need to using brazing rod, not solder. You can purchase Lincoln brazing rods at Home Depot (the 3' rods), and they will work...................but many others will suggest Silver Sav 56 rod. It is easier to work with, but the Lincoln stuff is okay. Some flux will also help you out, but I haven't found it to be 100% needed.
Robb is offline   Reply With Quote
Old 09-11-2006, 09:12 PM   #5
hey thanks alot im gonna try a diffrent type of brazing rod or maybe silver save 56 hopefullt it works out
Old 09-11-2006, 10:59 PM   #6
Colt Python/SR9c
TwistedCreations's Avatar
DO NOT take any of that advice
here is a writeup on tubers from Roktoy http://www.rccrawler.com/tuber.htm
thread moved also
TwistedCreations is offline   Reply With Quote
Old 09-11-2006, 11:12 PM   #7
So using an electric soldering iron will make all that hold.......seems iffy to me
Old 09-11-2006, 11:14 PM   #8
hahahaha
Nando is offline   Reply With Quote
Old 09-11-2006, 11:43 PM   #9
that was funny why?
Old 09-12-2006, 06:04 AM   #10
Colt Python/SR9c
Who said anything about a soldering iron??
Take the propane tank off and put on a "Mapp" tank. Get some safety silv, matching white flux, and some brakeline and build whatever you want. It is easier to tack the pieces together(if you have a mig) to hold them in place while you braze. if the chassis is designed right, a 200+ lb man can stand on top of a brakeline tuber
Old 09-12-2006, 10:29 AM   #11
He said soldering......i assumed, i know i shouldnt have.
It was a long day at work yesterday, and i wasnt in a good mood, sorry for the confusion.
