07-10-2013, 11:18 PM | #1 |
Rock Stacker Join Date: Apr 2013 Location: NW Washington
| Length formula for DIY allthread/tube links w Revo ends
If this is in the wrong place, please move it. I just made metal links using 8/32" all thread and 1/4" brake line for my Honcho. I used Revo link ends, so these numbers are based on the Revo link ends. For the all thread: Figure out your total length eye to eye that you want your link to be. Then subtract .575" and that will be the length to cut your all thread. If you are metric it would be 14.605 mm. For the brake line/tubing: Figure out your total length eye to eye that you want your link to be. Then subtract 1.33" and that will be the length to cut your tubing. If you are metric it would be 33.782 mm. Then just slide the tubing over the all thread and screw the Revo ends on! Should be dead on! Hope this may help someone. Once I figured out these numbers it was really fast to make all the parts. |
07-11-2013, 09:16 AM | #2 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
| Re: Length formula for DIY allthread/tube links w Revo ends
Yep, Im not as exact, but 14mm always works |
07-11-2013, 09:18 AM | #3 |
I eyeball them! |
07-11-2013, 10:51 AM | #4 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
i use 15mm for the sleave
10-18-2013, 11:22 AM | #5 |
Rock Crawler Join Date: Oct 2011 Location: Canada
I need the part number you guys are using for the rod ends so I can order some (the ends that work with this formula)
10-18-2013, 11:54 AM | #6 |
| Re: Length formula for DIY allthread/tube links w Revo ends |
10-18-2013, 12:51 PM | #7 |
amazing thanks!
01-13-2014, 03:03 PM | #8 |
Quarry Creeper Join Date: Mar 2009 Location: Grande Prairie, AB, Canada
this is perfect. every one should print this off and post on there work bench.
09-27-2014, 03:06 PM | #9 |
Pebble Pounder Join Date: Sep 2013 Location: Jacksonville
I use 5525 end links. U can get more thread into them. Then use 1/4 poly tubing instead of break line and it slides like delrin on the rocks. Great post!
09-28-2014, 06:21 PM | #10 |
Revo ends are 5mm longer than stock axial ones
10-02-2014, 09:35 AM | #11 |
Rock Stacker Join Date: Sep 2014 Location: MD/PA Line
Thanks - just ordered some parts to give it a shot for my MRC.
Length formula for DIY allthread/tube links w Revo ends - Similar Threads | ||||
I am trying to add Traxxas 5347 Revo rod ends to my STRC links, HELP!! | ZippoMan | Axial Wraith | 8 | 11-13-2012 04:00 PM |
DIY links -- rod ends? | WAM | Newbie General | 32 | 11-29-2011 10:52 AM |
Stainless steering links, allthread, and nylon ends | RickM | Axial AX-10 Scorpion | 7 | 03-16-2010 08:39 PM |
REVO rodends for DIY links | winks | General Crawlers | 2 | 01-07-2006 05:48 PM |
