01-04-2015, 03:43 PM | #1 |
Pebble Pounder Join Date: Jan 2013 Location: USA
| Allen or Hex Drill
Does anyone make a small RC specific Drill that will accomodate allen/Hex heads? Im sick of using those allen wrenches.
01-04-2015, 04:56 PM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Allen or Hex Drill
Check this one out, even though I never recommend using power tools for screwing into plastic. https://www.ryobitools.com/power-too...ts/details/375 |
01-04-2015, 09:01 PM | #3 |
Rock Crawler Join Date: Nov 2006 Location: Spanish Springs, Nv
I have this. You can adjust the torque. Has adjustable clutch. Never stripped any plastic on the low settings. Makita LCT200W 18-Volt Compact Lithium-Ion Cordless Combo Kit, 2-Piece - Power Tool Combo Packs - Amazon.com |
01-04-2015, 09:34 PM | #4 |
Pebble Pounder Join Date: Mar 2012 Location: Port Angeles
I use a Bosch ps20. It's similar to the ryobi mentioned above. Any of those small screw guns with a 1/4" quick release and adjustable clutch will work just fine. You can even use a drill that has an adjustable clutch and use straight sections of hex keys. As they wear down just file or grind the tip off and good as new again.
01-04-2015, 09:50 PM | #5 |
RCC Addict Join Date: Jul 2008 Location: San Diego
Who made 1.5mm 2.0mm Allen quick release 1/4 bits?
01-04-2015, 09:58 PM | #6 |
| Re: Allen or Hex Drill I use this with the impact driver. Out of stock at RPP http://www.rpphobby.com/product_p/losa99130.htm |
01-04-2015, 11:06 PM | #8 |
| Re: Allen or Hex Drill I get mine from McMaster, they are way cheaper than anywhere else and are sold individually so you can buy only the ones you need. I have used them a lot over the past few years and other than ruining the tip off the 1.5mm one (I bought 2 figuring this would happen) the rest are all good as new. Buy the "power" tips they are longer although not as long as some of the RC specific ones, hasn't been an issue for me so far. |
01-08-2015, 10:52 PM | #10 |
Those drills appear to large. I'm looking for something that can speed up removing small Allen or hex screws. I find the traditional Allen wrenched a major pain in the butt. Sent from my iPhone using Tapatalk |
01-08-2015, 10:55 PM | #11 |
I don't need a drill perse I'm more looking for very small hex drill bits that will work with the small hex screws that come on most RCs. Would something like this work? How small hex bits do I need? DEWALT DW2068 Hex Insert Bit Set, 9-Piece https://www.amazon.com/dp/B000628SO2..._EY2Rub0H4924T Sent from my iPhone using Tapatalk |
01-08-2015, 11:23 PM | #12 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
Mip Thorp! They make the best!
01-08-2015, 11:27 PM | #13 |
So this? Mip 9511 MIP Standard Speed Tip Set https://www.amazon.com/dp/B00D7DJTVI..._js3Rub0TYRM92 Sent from my iPhone using Tapatalk |
01-09-2015, 12:39 AM | #14 |
RCC Addict Join Date: Aug 2013 Location: Calgary - in the Great White North
Yup. And get these while you're at it. |
Allen or Hex Drill - Similar Threads | ||||
Hex set for power drill ? | scrofcheck | Tools, and Procedures | 16 | 01-19-2012 01:57 PM |
Hex size for allen wrenches. | arctichorse | Axial SCX-10 | 8 | 04-12-2011 04:08 PM |
Hex Drill bits | Lemonlegs28 | Tools, and Procedures | 11 | 01-03-2011 11:08 PM |
hex drill bit | Thorsteenster | Tools, and Procedures | 24 | 07-03-2007 05:05 PM |
