01-12-2016, 06:19 PM | #1 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| Got a question for any body
I bought some 1/8'' steel plate and want to cut some Chassis rails out for my 1:6 R/C project I used rubbing alcohol to clean off the oily film on the metal And started to scribe my lines with a sharp metal scribe and I can not see them after scribing them does any body know of a trick or something else I could use for my layout ?? I tried to find some Blue Dykem locally and can not find any and have to order some, I could have cut out by the time it ships If I could get them laid out and colored PVC glue will not stick to the metal and soap stone sucks cause it wipes right off and doesn't stick is there some thing else I can use ?? Last edited by kgb424; 01-12-2016 at 06:23 PM. |
01-12-2016, 06:31 PM | #2 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
| Re: Got a question for any body
lay a nice big line with a sharpie about where you're aiming to scribe your lines, then scribe over that. cheap, available, works well.
01-12-2016, 07:01 PM | #3 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
Blue painters tape.
01-12-2016, 07:13 PM | #4 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
I have done it both ways and I think using the blue painters tape is easier to follow your cut than a scribed line. |
01-12-2016, 07:35 PM | #5 |
Web Wheeling Join Date: Jan 2005 Location: Twin Cities
I use a markal pencil for my layout marks on steel. Makes really clean sharp lines. Works better on hot roll with mill scale. On shiny metal I use a sharpie, and if I need more precision I will scribe over the sharpie marks. Silver-StreakŪ Metal Marker (Silver) | Markal |
01-12-2016, 07:39 PM | #6 |
I bought BI-Metal jigsaw blades and I also have a couple air 3'' cut off tools I just thought using the jigsaw would be easier to adjust your cutting by being able to see the lines clearly and use a clamped straight edge to guide the jigsaw straight so the cuts are fairly clean and don't require a lot of clean up and there is not a lot of heat to make your lines disappear The cut off tools, I have no guides and it is hard too make clean straight cuts and your lines disappear from the heat of the cutting wheel I just ordered 2 of those Markal Welding Pencils one in silver and one red there are no place here locally, I picked a local company and ordered them online that ships Ups so I could get fairly quick now that Holiday rush is over Last edited by kgb424; 02-04-2016 at 02:38 PM. |
01-13-2016, 07:17 PM | #7 |
Rock Crawler Join Date: May 2009 Location: Welderville just south of benchviseland
Bummer about the dykem man... You could hit it with some cheap rattle-can, let it dry, then scribe your lines... And once you've got it cut out, just hit it with the brake parts cleaner and you're clean as a whistle.
01-14-2016, 12:08 AM | #8 |
The rattle can Idea might work but I would use the Rust Oleum primer the red rust color, cause the plate is black so the paint sticks and then a light second coat after its cut out then a couple coats of flat black I ordered the welding pencils if those don't work then I use some primer Last edited by kgb424; 01-14-2016 at 12:12 AM. |
01-19-2016, 05:54 AM | #9 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
I use a wide tip sharpie and never had any troubles with it ever ....
04-05-2016, 02:34 AM | #10 |
Newbie Join Date: Apr 2012 Location: San Diego
the thin striping tape works pretty well. some good blue tape is usually pretty available and easy to use.
04-05-2016, 08:08 AM | #11 |
Newbie Join Date: Jan 2016 Location: Cottage Grove
You could also try dykem as well after you scribe your line.
04-13-2016, 08:09 PM | #12 |
Newbie Join Date: Mar 2016 Location: louisville
I just use sharpie. Cheap and easy.
04-14-2016, 07:35 AM | #13 |
We've had guys here at work print out a 1:1 drawing, and then use some 3M spray adhesive to stick it down to what they want to cut out.
04-14-2016, 11:31 AM | #14 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
| Re: Got a question for any body |
04-14-2016, 11:43 AM | #15 |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
I've had to use a jig saw like a scroll saw many times.. I made a quick base out of 8x10" laminate flooring (smooth) clamped it in my vice with the trigger locked... plug and let her rip !... as for the metal I usually hit it with the sander, scribe out my lines, hit them with pencil lead like I was using a food slicer..(scribbling) wipe down the surface and cut away.. Tape and sharpies work Awesome for a lot of things but not so much with heat.. just my experience.. AND NEVER CUT TO THE LINE !! Give your self a little space!!! Always sand to fit if you want to have your efforts to come out right.. Good luck man all with basic hand tools.. Not that it's a spectral just a example |
04-15-2016, 10:53 PM | #16 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
Get some dykem so you got it for the future... trust me it is worth it for the $$$$ and hassle to get! That said I have used sharpie before with decent results. The idea is you want something that gives a visual contrast on the part so it is easier to see your scribe lines. I can see how you could use enamel paint from a hobby shop, slop that on the steel and go from there I agree with CHUD that having a 1:1 cut out is super nice! And yes NEVER cut on the lines or your going to regret it... always leave stock for finishing. It is easy to take metal off. It is a pain to put it back |
04-16-2016, 12:18 AM | #17 |
I scribed the lines and used the jigsaw too cut them It took a little grinding to get them close I finished them off with a file It took me awhile I like how the chassis rails came out Last edited by kgb424; 12-11-2018 at 01:42 AM. |
04-16-2016, 01:12 AM | #18 | |
| Re: Got a question for any body Quote:
BTY your signature should say (R.C) Rock smoker LOL | |
Got a question for any body - Similar Threads | ||||
body question | Leadchucker | General Crawlers | 2 | 01-28-2013 09:24 PM |
body question | redjeeper | Axial SCX-10 | 9 | 11-15-2009 10:12 PM |
Body Question | 322 | Tamiya CR-01 | 3 | 09-11-2009 08:20 AM |
Body question | LST022752 | Paint and Body | 3 | 09-23-2008 07:45 PM |
Body question | truegaintfree | Tamiya TLT Crawlers | 2 | 08-04-2005 07:34 PM |
