11-25-2016, 08:21 AM | #21 |
| Re: Machining question
That's a clean looking knee mill. Do you have any other pictures of the space? I'm kind of a geek when it comes to checking out other shops.
11-25-2016, 08:57 AM | #22 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
| Re: Machining question |
11-26-2016, 02:39 PM | #23 | |
| Re: Machining question Quote:
Home - The Foundery | |
12-06-2016, 08:06 PM | #24 |
Got the jaws finished today. I had to make an undercut clearance for the head of the spike to clear a moving part in the jaw, but overall it's going to work out just fine. I'll go back tomorrow and start cutting up the spikes. |
12-07-2016, 06:07 AM | #25 | |
So basically you buy a membership and can use the equipment? Id never be home. I like the hat/coat rack idea though, is that what you're making? | |
12-07-2016, 06:51 AM | #26 | ||
12-07-2016, 07:34 AM | #27 | |
If I wanna learn how to solder , no real equipment ones like those yet. | |
12-07-2016, 02:53 PM | #28 | |
I had to sit through the class that was taught by the equipment salesman that sold them the lathe and mill before I was "qualified" to use it. I just found it ironic that I was able to use the equipment prior and that I was qualified enough to turn out some parts for them but when I wouldn't get on board with a 3 hr intro class, suddenly I didn't know enough to use the equipment. | |
12-27-2016, 08:15 PM | #29 |
For Juan, sorry it took me so long to click a few pics. I'll get a clear pic of the under cut the next time I have the jaws out. I basically did a mass clearance where the spike head would be, then a 45* chamfer on the edge. the finished product. |
04-02-2017, 08:05 AM | #30 |
Quarry Creeper Join Date: Jan 2016 Location: Southampton
I don't know if you are still updating this thread but, just a thought. Couldn'you just use a stop on the vice jaw? Use an edge finder to locate center of first spike and remaining spikes would be close enough. On the 45 degree problem, it's very simple trig (is any trig simple.) Mark your center of your groove where you want it. Line up edge of cutter just so it will start cut on centerline with part at 45 deg. I like to use X axis on mill for moving because it is powered on mine. To keep cut centered move Y axis in the same amount as you come down on Z axis. Because you are using edge of cutter for aligning, it doesn't matter what diameter it is, as long as it is wide enough for cut. If Z does not have a readout for movement, lock in position and move the knee up instead. All mills I have worked with have readouts on the dials that can be set to zero, even the knee. Depending on tollerance you are trying to hold this is quick. I find the fixturing sometimes is more difficult to design than the part. Hope this helps.
Machining question - Similar Threads | ||||
cnc machining | josh6575 | Tools, and Procedures | 16 | 12-06-2012 10:46 AM |
General gear tooth machining question...from a nube... | ChattyMatty | Newbie General | 2 | 01-11-2010 06:51 AM |
Making custom rims/Machining question | Redfinger | Tires and Wheels | 19 | 11-24-2009 12:55 AM |
