12-19-2016, 09:05 AM | #1 |
Quarry Creeper Join Date: Mar 2016 Location: Moses Lake
| Standard Or Ball Hex Drivers?
just wondering is standard or is ball end Hex drivers? Is standard better than Ball end or is ball end better than standard? or is there no real difference and its just personal preference? Any insight on this would be great looking to replace my current tips for some new ones (have the replaceable type shaft) mine are getting warn out a bit and dont want to strip any screws. thanks |
12-19-2016, 09:08 AM | #2 |
RCC Addict Join Date: Aug 2008 Location: Paulina
| Re: Standard Or Ball Hex Drivers?
MIP tools are pretty darn good. I prefer standard tips.
12-19-2016, 09:14 AM | #3 |
Balls will fit looser, easier to strip screws Buy MIP once and done Hang up and Drive |
12-19-2016, 09:16 AM | #4 |
oh ok so the ball ends are actually worse? so ill stick to standard then thanks
12-19-2016, 11:16 AM | #5 |
Standard straight tips for sure! Ball tips are only for use when you can't access the screw straight on. But you also can't apply full torque to ball drivers or you risk stripping the screw heads. |
12-19-2016, 11:21 AM | #6 |
| Re: Standard Or Ball Hex Drivers? |
12-19-2016, 02:49 PM | #7 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
I would use metric, not many STANDARD screws on these trucks |
12-19-2016, 04:00 PM | #8 |
...I have and use both straight on access, max hand force = straight cut (hardened tip) drivers ^ straight cut tips cannot be angled whatsoever. angled access, light hand force = ball drivers ^ the ball drivers come in handy when a straight shot is not easily obtainable. generally... the majority of metric rc's only utilize 3 sizes (1.5, 2.0 and 2.5) So if purchasing a package of assorted drivers you won't be using, becomes a waste of money and storage space needed to accommodate. Get only the driver sizes you will need/use. btw... the crappy soft metal screws included in most kits round out easily when using ball or straight cut drivers So it's not always the fault of a worn ball driver. Upgrade the screws to the harder stainless steel... and they and the ball drivers won't round out as easily. Last edited by TacoCrawler; 12-19-2016 at 06:52 PM. |
12-20-2016, 02:38 PM | #9 |
Get both but learn when and where to use each. They both have their uses which is why they still sell both.
12-20-2016, 02:57 PM | #10 | |
| Re: Standard Or Ball Hex Drivers? Quote:
http://www.miponline.com/store/mip2003.html Here you go ! Hang up and Drive | |
Standard Or Ball Hex Drivers? - Similar Threads | ||||
ball hex vs. hex driver | DRW-FJ40 | Newbie General | 12 | 04-07-2010 11:56 AM |
Hex drivers...... | tjcrawler | Tools, and Procedures | 39 | 09-22-2009 07:29 PM |
