10-14-2018, 05:57 PM | #1 |
| Suspension link measuring tool.
I always seem to struggle when measuring suspension links accurately. I have tried a number of methods to get accurate repeatable dimensions, some work and some not so much. Back in June on Harleys YouTube channel, Josh did a video about tools in his toolbox. https://www.youtube.com/watch?v=6gorQKZBl1M&t=556s In that video he pulled out a tool at about the 4.00 minute mark and simply described it as his custom made link measuring tool then said nothing more about it. I have been thinking about that tool and it made me wonder if anyone sells an actual link measuring tool. It can't be hard to make one. I envision a tool that is basically nothing more than a common caliper with parallel 3mm rods in place of the normal jaws. To measure a link you would simply slip the link ends over the pins and would be able to read the length accurately and repeatably. I have considered taking one of my cheap digital calipers and soldering a pair of 3mm pins on the jaws but I wanted to check first if anyone currently sells something like this. BTW, for any company interested, this might be a good product idea. Just Sayin. Last edited by Inspector86; 10-14-2018 at 06:03 PM. |
10-14-2018, 06:28 PM | #2 |
Rock Stacker Join Date: Sep 2018 Location: Monroe Township
| Re: Suspension link measuring tool.
I just use digital calipers, but if you really want a dedicated tool, you can check this one out: https://www.integy.com/st_prod.html?...48&p_catid=163 |
10-26-2018, 10:13 PM | #3 |
Rock Stacker Join Date: Oct 2014 Location: Raeford
Anyone understand why the degree measurements?
10-26-2018, 11:40 PM | #4 |
I would assume to see if you have rebound set similarly between 2 shocks.
10-27-2018, 12:15 AM | #5 |
Cheap, accurate and fully repeatable. The bolts are 1/2" apart so eye to eye distance is easy to figure. |
10-28-2018, 09:46 PM | #6 | |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
| Re: Suspension link measuring tool. I don't like where this story is going. In that video he states "not something you can actually buy" If you have a mill you can easily make one of those Quote:
Nicely done Last edited by rockhugger; 10-28-2018 at 09:51 PM. | |
Suspension link measuring tool. - Similar Threads | ||||
Custom link measuring advice, and Drive shaft angle | Headrunner | Newbie General | 5 | 07-08-2014 08:09 PM |
What is 4-link suspension | MlgxBmx | Losi Mini-Rock Crawler | 8 | 01-13-2010 07:28 AM |
one link suspension | Kranberry | General Crawlers | 8 | 12-18-2006 11:47 PM |
4 link suspension ????'s | Jeeprockcrawler | Traxxas Crawlers | 9 | 08-22-2005 10:51 PM |
Anyone tried 3 link suspension? | BENDER | General Crawlers | 5 | 12-30-2004 09:53 PM |
